Hi, I have Inventor 2013. I've tried to import someone else's 2010 + 2012 version drawing borders but I get the message that they were created on a newer version of 'schema' files.
These others now have version 2014 and whilst they may have opened the borders in this newer version they did not let them update (apparently).
Is it possible the 'schema's' automatically updated and if so can I copy their 'schema's' into my schema file location to resolve the issue?
Solved by JDMather. Go to Solution.
Apparently they did update.
In Windows Explorer right click on the filename and select iProperties.
What does iProperties report as the current Inventor version of the file?
The "schema" error is typically what one sees when opening a file from a new version of IV with an old version. In your case, you have IV 2013 and the others have files created by IV 2012, but migrated to the 2014 release.
There is no option to save 2014 files in a native format that 2013 can read. Part and Assembly files can be saved as a .stp or other data interchange format, but you lose all the model tree.
Your options:
1. MIgrate to 2014.
2. Export the 2014 drawing borders to AutoCAD and try to bring them in to 2013. There may be manual work to make the 2013 borders correct.
3. Re-create the 2014 borders manually in 2013.
4. Have the 3rd party pull the 2010/2012borders from their offline backups, that were made before the 3rd party's migration to 2014, and use those.
Steve Walton
1. MIgrate to 2014.
Can't afford it!
They're using dwl's.!
Might have to but trying to avoid this tedious task.
Sounds like the best option - if copying over the schema's won't work.
