Inventor Forum
Importing Points
7 REPLIES 7
Message 1 of 8
2992 Views, 7 Replies
Importing Points
Im trying to make a wing by importing the cross section coordinates into a 2D sketch.
I was originally importing spreadsheets made in open office but saved as .xlsx and .xls, but have since attempted it with .xls files created in excel.
Once I select a file to import and press OK, the pop-up window closes and then nothing happens. I have tried this numerous times with numerous different files, and with each type of import (point, line, splice).
The spreadsheets are properly formatted (see attached) and I have tried removing the scale and the x y z column titles, and I still got nothing.
Any suggestions would be muchly appreciated.
Sam
Tags (3)
7 REPLIES 7
Message 2 of 8
JDMather
What version of Inventor? 2010? 2011? 2012?  Have you installed all Service Packs for your version?
Attach you xls file here to see if it works for others.
Message 3 of 8
Im using AutoDesk Inventor Professional 2012, and I have installed service pack 1.
I've attached my xls file.
Message 4 of 8
JDMather
I verified that the xls works fine on my machine - so now we need to figure out what is different on your machine.
Message 5 of 8
in reply to: JDMather
Thats the same screen that I have, minus the drawing.
I have the free version for students but I dont think that should make a difference. Is there anything you need to do to prepare the sketch before you start importing points?
I have followed this tutorial to the letter, but it doesn't solve my problem. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8324557&linkID=9242018
The most annoying thing is that the window to choose the file just closes when I press 'open' and no error message appears.
before
after
I've just noticed that it has the option to 'Repeat Import Points', but when I undo, It closes the part like it would normally with a part that had nothing in it.
Message 6 of 8
JDMather
I am using the student version - it is fully functional.
Message 7 of 8
Your problem could be that Inventor needs to have excel installed to import the data. I had a similar but more severe problem with ProE. It would not even run without excel installed. good luck.
Message 8 of 8
I am experiencing the same problem. I fixed it by having one of my friends sending an .ipt with the points already imported.
