There is an excellent tutorial out there that shows how to get Mechanical Desktop parts into Inventor. Problem is, it only seems to work when you're importing a single part. If the MDT file you're trying to import is an assembly (I'm guessing that's the right term - I was never an MDT user) then all it does is throw up an error and you're outta luck.
Anyone have a workaround for this?
Rusty
@michaeldavis7418 wrote:
step or sat it out .... I have to do this for a customer ...and all the parts came in as individual ipt's assemblys. Might have to feature recognize them after if it's a dirty part ... Sometimes you can open the assembly right in inventor too ..but I've found translating works much easier.
If I had access to Mechanical Desktop, that's what I'd probably do.
I'm looking for workarounds using the workflow that's built in to Inventor.
Rusty
what about Autocad
I can get the drawings, but not the models, so far as I've been able to discover.
Rusty
I don't have a MDT file at the moment to confirm this, but within the last month or two I found that same link and I had success at bringing in an assy - I was happy to finally have a solution! In the past we could not get MDT 2009 to install completely, we could only get it to work for the free 30 days.
If you could supply a .dwg MDT file, I'd be happy to test this once more.
Shoot me a PM with your email, Ampster. I'll send you over a file. The ones that I have are proprietary, so I can't post them here.
Thanks!
Rusty
Done. I'll wait to receive your file and private reply (if needed) before posting my results.
What update are you up to with 2014? I'm currently running it with no updates or service packs. What I'm thinking is I could try before updating and then after - hopefully seeing some different results!
You should have email now! Thanks, I really appreciate it.
I'm running 2014 fully updated to ... I guess it's SP1 update 3 now. 2015 obviously with no service packs or updates. I get the same result in both for the two files I sent you.
These files are proprietary information, so any files that you are able to get out of this, please don't attach them here. 🙂
This is the error message that I get with every single MDT assembly:
Rusty
just adding that I discovered during the import process where Inventor prompts you to select a template file to base the import off of, it only contains a .ipt template option, not .iam...
not sure if that's anything to report....just throwing it out there.
up to the top with a screenshot showing possible missing .iam tempate option.
I did hit the "escalate" button ... it was logged as Case 09501753 on 22 April 2014.
Rusty
@rdyson wrote:
If you want to sent it to me, I still have MDT 2009 loaded. I should be able to convert it for you.
Much as I'd love to take you up on that one, I don't think you could really afford to spend 40+ hours a week for the next couple months converting all our MDT files for us. 🙂
Rusty
