Hello everybody,
I can't find import points command at 2D sketch mode. I do right click at toolbar / customize / commands / 2D sketch and there is no import points. I run Autodesk Inventor 2007. Is this version supports this?
Thanks in advance
Welcome to the forum.
I just started using Inventor in 2011.
I have to ask, if you are using 2007 Inventor, what version of office Excel are you using?
It doesn't look like this command was around in 2007.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17368641&linkID=9242018
Can you post a screen shot in the 2007 sketch environment.
I think it was there, somewhere, but need a jog of memory.
If I remember this has to be done in 3d sketch mode. If you want it on a 2d level in the Z column make them all the same like all Z to be 0
I don't think the 2d import came till 2008-2009..
But as JD I don't remember long time ago if I was there I could tell you or take screen shot like JD asked for.
Here is 2D sketch environment http://imageshack.us/photo/my-images/202/80930909.gif/ and return from sketch http://imageshack.us/photo/my-images/716/41786442.gif/
