Inventor Forum
Importing DXF files
3 REPLIES 3
walterking103
251 Views, 3 Replies
Importing DXF files
Hi there!
I can import the DFX file into a sketch but when I finish the sketch I can't extrude the profile... I can only select all the lines that make up the profile. Any help is greatly appreciated!
Walter
3 REPLIES 3
blair
in reply to: walterking103
Most likely you have an Open Profile, while you are still in the active sketch, RMB on the model screen window and select "Sketch Doctor". Let it run through and diagnose the sketch for open profiles. Most likely you will have a number of them depending on how well the CAD model was done.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
JDMather
Did you have the Import Option set to Constrain Endpoints?
No I didn't change any of the options. Sketch doctor fixes the problem. I just have to click yes about 100 times as it combines all the points, but it works!
