I imported a mesh (.dxf format) in Inventor, but its appaerance is transparent. How can I remove the transparency? I tried applying different materials (which are not supposed to be transparent), but my mesh is still transparent.
Thank you for your help.
Best,
Julia
Solved by JDMather. Go to Solution.
Did you convert to a solid?
Did you try right clicking on node in browser and turn off Translucency?
Can you attach the file here?
Oh my God. I fell a bit stupid now.
I didn't see the "translucency" button...
Thank you very much!
Translucency is not all, Lucia.
What are you seeing at top of the part browser? Body or surface?
Walter
Walter Holzwarth
