Inventor Forum
Import problem
12 REPLIES 12
Message 1 of 13
743 Views, 12 Replies
Import problem
I have a 3ds max file that the company i work for needs to get into inventor.  I have tried exporting the file to .sat, .iges, and .dwg file an none have imported the assembly into inventor properly.  Any suggestions on what the problem could be and how to fix it?
12 REPLIES 12
Message 2 of 13
MariaManuela
Software releases please....
Asidek Consultant Specialist
www.asidek.es
Message 3 of 13
in reply to: MariaManuela
Inventor 2010 suite and 3ds max 2012.  the exported dwg file will open in autocad but not in inventor.
Message 4 of 13
JDMather
Why not?  Attach the dwg file here.
Message 5 of 13
in reply to: JDMather
the import finishes without any errors but none of the parts show up.  not sure what the porblem is, maybe a settings issue???  i would gladly attach the file but it exceeds the allowable size.
Message 6 of 13
JDMather
What does List return in AutoCAD?
Send to jmather_at_pct_dot_edu
Message 7 of 13
what do you mean?
Message 8 of 13
watertight mesh = yes
initial mesh face count = 624
this is the message in command line.
Message 9 of 13
JDMather
Send me the dwg file.
You could try the Sculpt icon (I don't know the command-line command) in AutoCAD first - but I suspect it will fail.
Message 10 of 13
i would love to send you the file but i've tried and it is to large even after compressed.
Message 11 of 13
MariaManuela
Use https://www.filemail.com/ to send large files for free
www.asidek.es
Message 12 of 13
JDMather
You do have to have the Options set correctly.
I imported this mesh.dwg and converted to solid.
(you won't be able to open my ipt files since I'm using 2012)
Without your file it is hard to say what the problem might be.
In general 3ds files are of little use in an engineering program for anything other than reference as the geometry consists of coarsely faceted surfaces.
Message 13 of 13
JDMather
Make sure you set the Options to Import
and set the destination for non-solid 3D geometry (this is a bit misleading in the dialog box.
On a file of your size it will take some time to open.
