Inventor General
Active Member
djlilmattie
Message 1 of 13 (145 Views)
Import problem
145 Views, 12 Replies
02-15-2012 06:08 AM
I have a 3ds max file that the company i work for needs to get into inventor.  I have tried exporting the file to .sat, .iges, and .dwg file an none have imported the assembly into inventor properly.  Any suggestions on what the problem could be and how to fix it?
MariaManuela
Message 2 of 13 (135 Views)
Re: Import problem
02-15-2012 07:02 AM in reply to: djlilmattie
Software releases please....
Maria Manuela Pinho
Application Specialist
Cadtech - Asidek | Autodesk Gold Partner
Autodesk Inventor Professional 2014 | Lenovo W520
Active Member
djlilmattie
Message 3 of 13 (124 Views)
Re: Import problem
02-15-2012 07:55 AM in reply to: MariaManuela
Inventor 2010 suite and 3ds max 2012.  the exported dwg file will open in autocad but not in inventor.
Message 4 of 13 (119 Views)
Re: Import problem
02-15-2012 08:06 AM in reply to: djlilmattie
Why not?  Attach the dwg file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Active Member
djlilmattie
Message 5 of 13 (108 Views)
Re: Import problem
02-15-2012 08:58 AM in reply to: JDMather
the import finishes without any errors but none of the parts show up.  not sure what the porblem is, maybe a settings issue???  i would gladly attach the file but it exceeds the allowable size.
Message 6 of 13 (100 Views)
Re: Import problem
02-15-2012 09:08 AM in reply to: djlilmattie
What does List return in AutoCAD?
Send to jmather_at_pct_dot_edu
Active Member
djlilmattie
Message 7 of 13 (93 Views)
Re: Import problem
02-15-2012 09:29 AM in reply to: JDMather
what do you mean?
Active Member
djlilmattie
Message 8 of 13 (90 Views)
Re: Import problem
02-15-2012 09:32 AM in reply to: JDMather
watertight mesh = yes
initial mesh face count = 624
this is the message in command line.
Message 9 of 13 (84 Views)
Re: Import problem
02-15-2012 09:44 AM in reply to: djlilmattie
Send me the dwg file.
You could try the Sculpt icon (I don't know the command-line command) in AutoCAD first - but I suspect it will fail.
Active Member
djlilmattie
Message 10 of 13 (82 Views)
Re: Import problem
02-15-2012 09:47 AM in reply to: JDMather
i would love to send you the file but i've tried and it is to large even after compressed.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
