Inventor General
*Sevier, Derek
Message 1 of 8 (69 Views)
Import from IGES
69 Views, 7 Replies
11-05-2002 04:04 AM
I finally got a big IGES file (17Mb) into Inventor. Now I am seeing all see
thru part and I notice in the browser there is a Construction folder. Under
that has group so I did the promote and picked the surfaces. It crashes
everytime so is there something I should do first before I promote the
surface to make it become solid? When I open IGES, I checked mark for Auto
Stitch and promote. It doesn't make any difference...Can one explain to me
because I have no experience with IGES or surfacing stuff?
Derek Sevier
Mechanical Engineer
Quality Corporation
derek.s1@donkeyforklift1.com
www.donkeyforklift.com
To reply, remove the "1's" from my email
Message 2 of 8 (69 Views)
Re: Import from IGES
11-05-2002 04:17 AM in reply to: *Sevier, Derek
As you apparently already know, IGES is a filetype for surface models. Inventor's Auto Stitch and Promote works great, provided the IGES surface is healthy. If there are miniscule gaps in the surface, it doesn't represent a closed surface, and Auto Stitch and Promote fails.
You'll need something like CADdoctor by Elysium to heal the IGES surface before importing it into Inventor.
*Howard, Jeff
Message 3 of 8 (69 Views)
11-05-2002 04:40 AM in reply to: *Sevier, Derek
Derek, have you tried to import and stitch in MDT? Can you describe the
parts in the file; curvy, simple, lots of them, etc.?
Jeff
"Derek Sevier" wrote in message
news:696478509E0FA660B4FF0545CE8E7D72@in.WebX.maYIadrTaRb...
Derek Sevier
Mechanical Engineer
Quality Corporation
*Sevier, Derek
Message 4 of 8 (69 Views)
Re:
11-05-2002 05:55 AM in reply to: *Sevier, Derek
It is an engine from Kubota...It definitely has alot of curves and tubes....
Derek Sevier
Mechanical Engineer
Quality Corporation
"Jeff Howard" wrote in message
news:868FD363CC117EA5D844913D4E58A6B8@in.WebX.maYIadrTaRb...
> Jeff
see
Under
> Thanks,
> Derek Sevier
> Mechanical Engineer
> Quality Corporation
*Howard, Jeff
Message 5 of 8 (69 Views)
Re:
If you don't have any choice except to work with the file, I'd try MDT. The
simplest approach is to import and see if there are any obviously goofy
surfaces. If things look ok, try to stitch using the defaults (select all and
let it cook) and see what you get. Using the healer functions of the stitch
command may help get the remaining quilts to join to solids. If this doesn't
get you anywhere, manually segregating surfaces and stitching individual parts
may get you farther along.
I suppose asking the source to regen the model to a tighter tolerance and
giving you a .stp is out of the question?
Good luck with it,
Jeff
news:8396DD7EC7C9FA435B85ED6098D28884@in.WebX.maYIadrTaRb...
Derek Sevier
Mechanical Engineer
Quality Corporation
*Reed, Darin S.
Message 6 of 8 (69 Views)
Re:
11-05-2002 06:12 AM in reply to: *Sevier, Derek
Do you have this software?
This email is never sent unsolicited. It
is only sent to you because you are lucky enough to know the
sender.
*Reed, Darin S.
Message 7 of 8 (69 Views)
11-06-2002 04:19 AM in reply to: *Sevier, Derek
http://www.transmagic.com/
try this, you get a 14 day trial.
This email is never sent unsolicited. It is only sent to you because you are
lucky enough to know the sender.
*Cooper, Doug
Message 8 of 8 (69 Views)
11-06-2002 10:27 PM in reply to: *Sevier, Derek
Derek,
Like you, I haven't had a lot of experience pulling IGES things in either, but
when I have made the attempt, it only sometimes worked. I had a choice of
Parasolid or IGES formats, tried the Parasolid style first (w/Xchangeworks and
MDT) and couldn't get a solid that would work properly in IV 6. I then went
back to the IGES file and directly pulled it into IV. Stitching and Promoting
left me a pretty smart IV part. I even got cocky enough to emboss "Femur" on
the human femur model, just to see if I could. It started out as a 6.5Mb IGES
file. Hope you got something to work.
Doug
> Thanks,
> Derek Sevier
> Mechanical Engineer
> Quality Corporation
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
