Inventor General
Active Contributor
MechEng_1
Message 11 of 15 (470 Views)
Re: Import STYXML files to Inventor 2013 materials library
01-11-2013 12:54 AM in reply to: ChrisMitchell01
Hi Chris,
Thanks for the reply, I have attached a few screenshots showing my workflow. I opened the one part file and carried all steps out within that one file.
The other thing i have noticed that if i pick the colour from the drop down box at the top, the colour is very bright with no shadows etc. I saw above that you need to change the diffuse values to 0,0,1 but they are already set at that.
Thanks again,
Mike
Employee
Message 12 of 15 (455 Views)
01-11-2013 03:06 PM in reply to: MechEng_1
Hi Mike,
You're doing the right things there; I don't know what's going wrong though - I just imported the same styxml file attached here to a new part file - see attached.
If you open this file do you see the RAL appearances on both the drop down & in the appearance browser ?
I'm using 2013 SP1.1 update1.
Chris
Chris Mitchell
Inventor Customer Enagagement Team
Active Contributor
MechEng_1
Message 13 of 15 (431 Views)
01-14-2013 12:32 AM in reply to: ChrisMitchell01
Hi Chris,
I tried saving your file and opening it and i had exactly the same problem, it shows in the dropdown but not in the appearance browser. This is driving me crazy!!
Thanks for the help.
Mike
Active Contributor
MechEng_1
Message 14 of 15 (427 Views)
01-14-2013 02:18 AM in reply to: MechEng_1
Chris,
Thanks again, i think i may have solved it. I noticed that i had the design data folder referencing a folder within my project instead of the default location. Once i had changed that back to the default it seems to have fixed itself. the ral colours now appear in the top section of the appearance browser.
Mike
Employee
Message 15 of 15 (412 Views)
01-14-2013 04:44 PM in reply to: MechEng_1
Ok Thanks for confirming, Mike.
I suspect that the Design Data folder you were previously pointing to didn't have a complete set of files in it if it was from a prior release.
-Chris
Chris Mitchell
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
