Solved by JDMather. Go to Solution.
Solved by KevinLi-Autodesk. Go to Solution.
Hi Rashpal,
Thanks for reporting!
Please refer to attached image.
You select the Options before even opening the file.
Select the file to open, and then BEFORE OPENING, select Options.
There is a chance your part will still be the wrong size, so check.
Do you know how to scale or change document units?
I accidentally found another way to bring STL into Inventor that gives remarkably good results without using Mesh Enabler - so I'm sharing 🙂
If you import the STL into 3ds max you have a number of tools to fix-up the mesh ("STL check" and "Cap holes" are good modifiers to try). However, if you are not a max user, you can just export the model as a .SAT file and open that in Inventor. Watertight meshes (no holes) become solid parts in Inventor - and meshes that weren't watertight become composites.
The only reason I mention this process is because (in my recent experience) STL meshes are often either very coarse (large facets) or very fine (tiny facets) and max has so many tools for dealing with these extremes. If you've ever taken a large STL file into Inventor, the face count can be horrific and the model size unworkable. The tools in max give you a good chance to refine the mesh to a sensible size before bringing it into Inventor.
Hi rashpal,
It's my pleasure! If you meet any other data translation issues please post in this forum or just contact me via Hongyuan.Li@autodesk.com , my team will take a look.
BIG thanks to JD !
Hi Rashpal,
STL format is a pure mesh data, when open it in Inventor and export it to .sat, nothing will be exported since Inventor does not support to export mesh data to .sat, if you open .sat file with Notepad++ you will see only the file header is generated but don't have detail data of geometry. So when open the exported .sat back to Inventor, nothing will be imported and translation report will prompt "No bodies read from file".
In 3DS Max I suppose it has some mesh tools or features to convert mesh data to brep (just like mesh enabler tool), need to convert mesh in 3DS Max first then exported to .sat, and also the exported .sat which contains brep information can be imported to Inventor,
Hi rashpal
It does work - honest! In max, import the STL file. Even if you don't know max at all, just export the model using .SAT format. After entering the file name you get another dialog with 4 options - tick "Export Mesh Objects (Objects collapsible to Mesh)"
When you go to Inventor and try importing the model, select the .SAT file name - then hit "Options" and make sure "Solids", "Surfaces" and "Wires" are ticked.
Any problems, post (or private message) the STL file you are trying and I'll see if there's something "odd" about it that causes the above to fail.
(Attached is the classic 3ds max teapot with the handle, spout and lid pulled off - exported as a SAT. You can bring this into Inventor with ease as a composite surface model, but not as a solid because the mesh is not watertight.)
With some unexpected free time this evening, I put this video together showing the max > Inventor workflow:
http://www.screencast.com/t/QQVxX0v45HxY
If you just want the import workflow, that's the first bit of the video.
The second bit of the video is reducing the polygon count. There are several ways to do it, but I figured 2 clicks in max was pretty easy to follow!
The last part of the video show how you could fix holes in your STL meshes - this way you stand a better chance of getting a solid body in Inventor.
Hope it helps.
I've been trying to use millimeters too, but the Options are greyed out. Even though I have the file selected.
Hi Brausmith,
Do you use Manage tab -> Insert -> Import to insert the STL file ? if this is the case, then the options will be grayed out since it is insert import. The options are available for Open.
