Inventor Forum
Import FBX into Inventor Pro 2013
2 REPLIES 2
luismestre
5551 Views, 2 Replies
Hi
Does anyone knows if is already possible to import FBX into Inventor Pro, is that possible already in 2015 version?
(I'm aware of Nurbs and facets geometry).
thanks
Luis Mestre
Oil&Gas Sr.3D & Subsea/Structural Designer
"Autodesk Autocad/Inventor & 3D Studio Max"
Email:lmsmestre@gmail.com
2 REPLIES 2
rdyson
in reply to: luismestre
FWIW, Rhino will open FBX files. Then IV will open the saved Rhino 3dm. But the utility of the translation is questionable.
PDSU 2016
MingweiGao
Hi, If you have 3DS Max and AutoCAD, you can Import the FBX file into 3DS Max and export it as DWG file. And then you can open the DWG file in AutoCAD and Switch to 3D Modeling, select the Mesh tab, and change the mesh to Smooth Optimized Level X. Then convert to Surface (Solid). Export to STEP (or other types). Open the STEP file in Inventor.
Steven Gao
Sr. SQA Engineer
