Show only
Search instead for
If you have 3DS Max and AutoCAD, you can Import the FBX file into 3DS Max and export it as DWG file. And then you can open the DWG file in AutoCAD and Switch to 3D Modeling, select the Mesh tab, and change the mesh to Smooth Optimized Level X. Then convert to Surface (Solid). Export to STEP (or other types). Open the STEP file in Inventor.
