Inventor Forum
Import 3Dpoly
3 REPLIES 3
602 Views, 3 Replies
Import 3Dpoly
How can I import a 3DPoly from Autocad into Inventor to use as path for a swepped profile for a barrel cam?
3 REPLIES 3
JDMather
File Open and set Options?
Why not create the path directly in Inventor rather than using AutoCAD?
Be very careful that you get the true geometry that you are expecting -
this is an old tutorial http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%2011.pdf
but it points out the difficulty in gettting the true geometry.
It is now easier since additional options were added to Sweep (w guide surface), but you still have to be very careful.
in reply to: JDMather
What I know about Inventor is: I haven't even installed it yet. What I do now is the following, I create the points with generally 0.25 degrees resolution in Mathcad, create a script file with all the points and with "3Dpoly" on top. That creates the curve in Autocad - no problem at all. Where the problem comes in is that Autocad can loft this into a solid as shown, but in no way can I select 1440 point by hand to create the profile. And _sweep doesn't work because the profile doesn't stay parallel to, let's say, the Z-Axis. So, I am looking for an Alternative.
JDMather
@Anonymous wrote:
What I know about Inventor is: I haven't even installed it yet.  So, I am looking for an Alternative.
Sounds like you might be doing too much work as the tools are already built into Inventor.
Simply an exercise in filling dialog boxes.
