I am trying to put an immediate update box on my form in ilogic. I want to be able to change parameters on my form without updating the model. There is this option in the parameters window but not in the form. How can I accomplish this?
Solved by theo.bot. Go to Solution.
Dear Joseph,
Change the button of the form into apply/cancel/ok.
Edit the form, select the form name, in the bottum area you can change the controll buttons.
Only if you hit apply or ok, the parameters will be changed.
Kind regards
Theo
