Inventor General
Active Contributor
helmartins
Message 1 of 3 (763 Views)
Ilogic error (changing sheet border and title blocks)
763 Views, 2 Replies
06-18-2012 05:37 AM
Hi
I'm having an error with Ilogic parameters (see the attachments).
I just wanna change the border and the title blocks with Ilogic. This should be simple. Isn't this?
Helder Martins
Curtis_Waguespack
Message 2 of 3 (729 Views)
Re: Ilogic error (changing sheet border and title blocks)
06-18-2012 11:09 AM in reply to: helmartins
Hi helmartins,
It's difficult to know what the problem might be with the information provided, but here are a couple of links that might help you get it sorted:
http://inventortrenches.blogspot.com/2011/05/use-ilogic-to-change-sheet-orientation.html
http://inventor-tales.blogspot.com/2010/11/drawing-conclusions-on-formatting.html
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
*Pro
jletcher
Message 3 of 3 (719 Views)
06-18-2012 12:00 PM in reply to: helmartins
this is my code works great you may have to take out the style change
trigger=iTrigger0
Dim drawingDoc as DrawingDocument = ThisDoc.Document
Dim stylesMan As DrawingStylesManager = drawingDoc.StylesManager
Trace.WriteLine(" --- Active drawing standard = " & stylesMan.ActiveStandardStyle.Name )
'Pick Sheet Size
Sheet_Size= InputListBox("Select Sheet Size", MultiValue.List("Sheet_Size"), Sheet_Size, Title := "Sheet Size", ListName := "Choose Sheet Size")
'A size
If Sheet_Size = "A (8 1/2 X 11)" Then
ActiveSheet.ChangeSize("A", MoveBorderItems := True)
ActiveSheet.TitleBlock = "Uni Pak A"
ActiveSheet.Border = "Uni Pak A"
stylesMan.ActiveStandardStyle = stylesMan.StandardStyles("Uni Pak A")
'B size
ElseIf Sheet_Size = "B (11 X 17)" Then
ActiveSheet.ChangeSize("B", MoveBorderItems := True)
ActiveSheet.TitleBlock = "Uni Pak B"
ActiveSheet.Border = "Uni Pak B"
stylesMan.ActiveStandardStyle = stylesMan.StandardStyles("Uni Pak B")
'C size
ElseIf Sheet_Size = "C (17 X 22)" Then
ActiveSheet.ChangeSize("C", MoveBorderItems := True)
ActiveSheet.TitleBlock = "Uni Pak C"
ActiveSheet.Border = "Uni Pak C"
stylesMan.ActiveStandardStyle = stylesMan.StandardStyles("Uni Pak C, D")
'D size
ElseIf Sheet_Size = "D (22 X 34)" Then
ActiveSheet.ChangeSize("D", MoveBorderItems := True)
ActiveSheet.TitleBlock = "Uni Pak D"
ActiveSheet.Border = "Uni Pak D"
'E size
ElseIf Sheet_Size = "E (34 X 44)" Then
ActiveSheet.ChangeSize("E", MoveBorderItems := True)
ActiveSheet.TitleBlock = "Uni Pak E"
ActiveSheet.Border = "Uni Pak E"
stylesMan.ActiveStandardStyle = stylesMan.StandardStyles("Uni Pak E")
End If
'update all
InventorVb.DocumentUpdate()
'zoom all
ThisApplication.ActiveView.Fit
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
