Inventor General
Valued Contributor
gazadder
Message 1 of 2 (261 Views)
Accepted Solution
Ilogic Save drawing as inventor dwg
261 Views, 1 Replies
04-24-2012 08:35 AM
Is there a way in an inventor drawing rule to do a "save as" which saves the drawing as an Inventor dwg file rather than an AutoCAD dwg file?
The below saves as AutoCAD which is ok but I need the outputted drawing to be linked to the model.
I don't want the code to save the entire assembly as this is done further down the line.
I also don't want to save the current inventor dwg drawing from which the rule is run as this is just a template drawing.
ThisDoc.Document.SaveAs(ThisDoc.Path&"\2D_DRAWINGS\"&iProperties.Value("Custom", "Drawing No.")&" (Rev "&Parameter("BEAUFORT_ARRANGEMENT_3.iam.DRAWING_REVISION_NO")&")"&".DWG", True)
Valued Contributor
gazadder
Message 2 of 2 (258 Views)
Re: Ilogic Save drawing as inventor dwg
04-24-2012 08:49 AM in reply to: gazadder
Format:HTML Format Version:1.0 StartHTML:     165 EndHTML:     614 StartFragment:     314 EndFragment:     582 StartSelection: 314 EndSelection:     314
SyntaxEditor Code Snippet
ThisDoc.Document.SaveAsInventorDWG(filename)
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
