Is there a way in an inventor drawing rule to do a "save as" which saves the drawing as an Inventor dwg file rather than an AutoCAD dwg file?
The below saves as AutoCAD which is ok but I need the outputted drawing to be linked to the model.
I don't want the code to save the entire assembly as this is done further down the line.
I also don't want to save the current inventor dwg drawing from which the rule is run as this is just a template drawing.
ThisDoc.Document.SaveAs(ThisDoc.Path&"\2D_DRAWINGS\"&iProperties.Value("Custom", "Drawing No.")&" (Rev "&Parameter("BEAUFORT_ARRANGEMENT_3.iam.DRAWING_REVISION_NO")&")"&".DWG", True)
Solved by gazadder. Go to Solution.
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 614 StartFragment: 314 EndFragment: 582 StartSelection: 314 EndSelection: 314
SyntaxEditor Code Snippet
ThisDoc.Document.SaveAsInventorDWG(filename)
