Inventor Forum
Ilogic Rule to change custom iproperty
1 REPLY 1
dclunie
2574 Views, 1 Reply
Hi
I am after help on writing part of rule for ilogic,i need the rule to fill out a custom property with information for me
I have a part that has 2 parameters
  1. parameter 1 = Frontplanangle
  2. parameter 2 = Endplanangle
Custom property
iProperties.Value("Custom", "DESC2") =
I need the rule to examine both parameters and if both angles = 0 then DESC2 = ""
And if any parameter >0 then
iProperties.Value("Custom", "DESC2") = bevel/
Regards
Dave
Tags (1)
1 REPLY 1
Curtis_Waguespack
in reply to: dclunie
Hi dclunie,
Something along these lines should work:
If Frontplanangle = 0 And Endplanangle = 0 Then
iProperties.Value("Custom", "DESC2") = ""
ElseIf Frontplanangle > 0 Or Endplanangle > 0
iProperties.Value("Custom", "DESC2") ="bevel/"
MessageBox.Show("DESC2 = " & iProperties.Value("Custom", "DESC2"), "iLogic")
 I hope this helps.
Curtis
