Hi
I am after help on writing part of rule for ilogic,i need the rule to fill out a custom property with information for me
I have a part that has 2 parameters
Custom property
iProperties.Value("Custom", "DESC2") =
I need the rule to examine both parameters and if both angles = 0 then DESC2 = ""
And if any parameter >0 then
iProperties.Value("Custom", "DESC2") = bevel/
Regards
Dave
Solved by Curtis_Waguespack. Go to Solution.
Hi dclunie,
Something along these lines should work:
If Frontplanangle = 0 And Endplanangle = 0 Then iProperties.Value("Custom", "DESC2") = "" ElseIf Frontplanangle > 0 Or Endplanangle > 0 iProperties.Value("Custom", "DESC2") ="bevel/" End If MessageBox.Show("DESC2 = " & iProperties.Value("Custom", "DESC2"), "iLogic")
I hope this helps.
Curtis
