style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"JDMATHER" <jmather@pct.edu>Try
wrote in message
href="news:f14d016.0@WebX.maYIadrTaRb">news:f14d016.0@WebX.maYIadrTaRb...
F1 and on the index tab type in the "word" IGES.
Do the same thing for
STEP.
IMOP this is one of those cases where either I am completely missing your
question, or perhaps you should consider a different career. One that does not
involve using computers. I am not trying to be smart here, I only want to
encourage you, in a way that you will never forget, to learn to use the help
screen. If I am off base and do not understand your question, I apologize.
I think the help screen will instruct you to do a File Save Copy AS and
select Save as type...
"KJohnson" <kj@sensoft.ca> wrote
in message
href="news:F2D022A6A1E6052696D5FE9D93A31D3B@in.WebX.maYIadrTaRb">news:F2D022A6A1E6052696D5FE9D93A......
From the help
"Specifies the options for exporting Autodesk Inventor
solid geometry data to IGES format."
I don't think it is possible to export construction surfaces.
Kathy
Johnson
"MechMan" <mechman> wrote in messageWould
href="news:f14d016.5@WebX.maYIadrTaRb">news:f14d016.5@WebX.maYIadrTaRb...
SAT files be of any use to you? I think they carry the surface
info.
MechMan
"JDMATHER" <jmather@pct.edu>I
wrote in message
href="news:f14d016.8@WebX.maYIadrTaRb">news:f14d016.8@WebX.maYIadrTaRb...
just verified that SAT will carry the Inventor construction surfaces.
Just
out of curiousity what program are you taking the surfaces to? When I opened
up the SAT file in MDT I had to issue the am2sf command to turn the surface
from a SAT surface to MDT surface.
