Oh well, maybe one day.
Let's face it one cannot model mechanics effectively without power
transmission. Relational motion can only model up to a point. Constant
contact transmission can be modelled in IV but not cyclical, intermittent
contact transmission.
I'd love to be able to model the conveyor systems I work with occasionally.
So my "Fishes" would be;
A Standard Gear wizard - Spur & helical with self calculating mesh depth
A belt wizard - Vee, flat, gated.
A standard chain wizard. - allowing use of attached pull fingers.
I've got a few years left in me... I'll wait ;o)
It's getting the boss to pay for what this work would cost that will kill me
;o)
Mark T. Mk II.
"Sean Dotson" wrote in message
news:5E2BA43D74876B793A0E2DF7A55CF472@in.WebX.maYIadrTaRb...
> It's a bit more complicated than that. It uses adaptivity.
> Chains and belts are difficult as their DOFs change depending on where
they
> are in the system (on a pulley, riding along a chain track, tensioned
> between two idlers etc..)
> That's a bit pf a kinematic mess. I wouldn't expect IV to handle
something
> like this for some time to come.
> Sean Dotson, PE
> http://www.sdotson.com
> Check the Inventor FAQ for most common questions
> www.sdotson.com/faq.html
> "Mark T." wrote in message
> news:57958F6E71FB3DE6ACC237C06BA10C69@in.WebX.maYIadrTaRb...
> > Constraining a coil feature at each end. Thus causing the resultant
solid
> > model to deform when driving this constraint. Something which I believe
is
> > still beyond Solidworks.
> > Mark T. Mk II.
> > "Jack Watson" <-> wrote in message news:f140495.0@WebX.maYIadrTaRb...
> > > Dynamic spring action???
