Inventor General
Member
Message 1 of 8 (319 Views)
Accepted Solution
Idw save as dwg changes dimensions Inventor Pro 2012
319 Views, 7 Replies
09-12-2012 01:43 PM
Every time I take an assembly and make an idw, I also need to do a save copy as dwg.  However when I do so, the dimensions of my assembly have changed.  Any thoughts?
*Pro
jletcher
Message 2 of 8 (316 Views)
Re: Idw save as dwg changes dimensions Inventor Pro 2012
09-12-2012 01:57 PM in reply to: dmatsalla
What do you mean change? The assembly changes size? The dimensions change and numbers are not right?
Need more impute please.. :smileyhappy:
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Member
Message 3 of 8 (312 Views)
09-12-2012 02:17 PM in reply to: jletcher
As an example, I will measure the height and place a dimension in Inventor.  It shows 93".  When I open the dwg file the dimension still shows 93", but when I re-measure the line, it is now 83"
This is not a scaling issue as it seems only certain values have changed, while others have stayed the same.
BTW, the idw is originally created from ETO if that makes difference.
*Pro
jletcher
Message 4 of 8 (294 Views)
09-13-2012 05:02 AM in reply to: dmatsalla
It can be a scale issue...
What settings did you use when you exported it to autocad?
James Letcher
Member
Message 5 of 8 (290 Views)
09-13-2012 07:07 AM in reply to: jletcher
I am using all of the deafult settings, saving it as AutoCAD 2010.
*Pro
jletcher
Message 6 of 8 (286 Views)
09-13-2012 07:51 AM in reply to: dmatsalla
I mean in this area here if you did not pick the right option it will scale in autocad..
James Letcher
Member
Message 7 of 8 (282 Views)
09-13-2012 08:08 AM in reply to: jletcher
Yes the right scale was picked.
Here is the interesting thing.  If I use the idw creayed by ETO, the drawing seems to be scaled.  If I create a new idw and save that one as a dwg, it works perfectly.
So for now, issue solved.
Distinguished Contributor
Message 8 of 8 (281 Views)
09-13-2012 08:13 AM in reply to: dmatsalla
I have had this issue.  And it's caused by what others have mentioned in this message.  When you save-as dwg in Inventor, some of the settings will scale the Inventor model to the idw view scale during the export to dwg.  If you select model 1:1 setting Inventor it won't do this.  However, the dwg will contain only the model and no dimensions/annotations/notes, etc.
Bottom line, Inventor doesn't export a "correct" AutoCAD dwg drawing.  Regardless of the settings you select in Inventor during the export you will have to spend time in AutoCAD to clean it up otherwise it looks like you have no clue how to use AutoCAD.  I use Inventor Product Design Suite Premium 2013 and it still acts as you are experiencing.  I hope Autodesk will improve this feature as I also get clients occasionally requesting a dwg file.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
