Inventor Forum
IV9 SP1 - Bug - iParts - Threads
8 REPLIES 8
Message 1 of 9
160 Views, 8 Replies
Iparts do not update when you have a hole feature that is a thread. If the iParts were created before release 9 it seems to be OK. If you create from scratch in Inventor Release 9 SP1 a rectangle of say 1 in x 1 in and thread of say a .112-40 UNC (#4) and then have the second row be 2 in x 2 in and a thread say .500-13 UNC (1/2-13) it will update the size but not update the thread. This is not too much of a problem unless you are making Pem Nuts that are round and when you change from a big size to a small size it will error out. Where do I go to have this resolved? Is there an AutoDesk web site for bugs or is this it? AutoDesk any help will be appreciated Thank You Dan Davison
8 REPLIES 8
Message 2 of 9
Notice the thread is not changing. The Chamfer, OD, Insert Length is. "Daniel Davison" wrote in message news:4192659b_3@newsprd01... > Iparts do not update when you have a hole feature > that is a thread. > > If the iParts were created before release 9 it seems to be OK. > If you create from scratch in Inventor Release 9 SP1 a rectangle > of say 1 in x 1 in and thread of say a .112-40 UNC (#4) and then > have the second row be 2 in x 2 in and a thread say .500-13 UNC > (1/2-13) > it will update the size but not update the thread. > > This is not too much of a problem unless you are making Pem Nuts > that are round and when you change from a big size to a small > size it will error out. > > Where do I go to have this resolved? > Is there an AutoDesk web site for bugs or is this it? > > AutoDesk any help will be appreciated > Thank You > Dan Davison > > >
Message 3 of 9
http://www.sdotson.com/freetut/using%20threads%20in%20iparts.pdf HTH Duncan @home -- "Humour ... is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be as mad as what passes for ordinary living." (Terence 'Spike' Milligan K.B.E., 1918-2002) "Daniel Davison" wrote in message news:41926761_3@newsprd01... > Notice the thread is not changing. The Chamfer, OD, Insert Length is. > > > "Daniel Davison" wrote in message > news:4192659b_3@newsprd01... > > Iparts do not update when you have a hole feature > > that is a thread. > > > > If the iParts were created before release 9 it seems to be OK. > > If you create from scratch in Inventor Release 9 SP1 a rectangle > > of say 1 in x 1 in and thread of say a .112-40 UNC (#4) and then > > have the second row be 2 in x 2 in and a thread say .500-13 UNC > > (1/2-13) > > it will update the size but not update the thread. > > > > This is not too much of a problem unless you are making Pem Nuts > > that are round and when you change from a big size to a small > > size it will error out. > > > > Where do I go to have this resolved? > > Is there an AutoDesk web site for bugs or is this it? > > > > AutoDesk any help will be appreciated > > Thank You > > Dan Davison > > > > > > > > >
Message 4 of 9
One other thing On the "Tapped Hole Diameter" setting under "Document Settings", I use "Drill Size" not "Minor" Dan Davison "Daniel Davison" wrote in message news:4192659b_3@newsprd01... > Iparts do not update when you have a hole feature > that is a thread. > > If the iParts were created before release 9 it seems to be OK. > If you create from scratch in Inventor Release 9 SP1 a rectangle > of say 1 in x 1 in and thread of say a .112-40 UNC (#4) and then > have the second row be 2 in x 2 in and a thread say .500-13 UNC > (1/2-13) > it will update the size but not update the thread. > > This is not too much of a problem unless you are making Pem Nuts > that are round and when you change from a big size to a small > size it will error out. > > Where do I go to have this resolved? > Is there an AutoDesk web site for bugs or is this it? > > AutoDesk any help will be appreciated > Thank You > Dan Davison > >
Message 5 of 9
Hi Thank you. I have seen Sean's documents. This appears to be a bug. "Duncan Anderson" wrote in message news:419269fb_2@newsprd01... > http://www.sdotson.com/freetut/using%20threads%20in%20iparts.pdf > > HTH > Duncan > @home > -- > "Humour ... is one man shouting gibberish in the face of authority, and > proving > by fabricated insanity that nothing could be as mad as what passes for > ordinary > living." > (Terence 'Spike' Milligan K.B.E., 1918-2002) > > > > "Daniel Davison" wrote in message > news:41926761_3@newsprd01... >> Notice the thread is not changing. The Chamfer, OD, Insert Length is. >> >> >> "Daniel Davison" wrote in message >> news:4192659b_3@newsprd01... >> > Iparts do not update when you have a hole feature >> > that is a thread. >> > >> > If the iParts were created before release 9 it seems to be OK. >> > If you create from scratch in Inventor Release 9 SP1 a rectangle >> > of say 1 in x 1 in and thread of say a .112-40 UNC (#4) and then >> > have the second row be 2 in x 2 in and a thread say .500-13 UNC >> > (1/2-13) >> > it will update the size but not update the thread. >> > >> > This is not too much of a problem unless you are making Pem Nuts >> > that are round and when you change from a big size to a small >> > size it will error out. >> > >> > Where do I go to have this resolved? >> > Is there an AutoDesk web site for bugs or is this it? >> > >> > AutoDesk any help will be appreciated >> > Thank You >> > Dan Davison >> > >> > >> > >> >> >> > >
Message 6 of 9
You have not defined a variable for the size of the hole. You must specify both the hole diameter AND the thread, not just the thread.
Message 7 of 9
http://www.autodesk.com/submitbug This is your starting point for sending a message to Autodesk. Use this form for general comments and questions, bug reports, wish-list items, piracy reports, and so on --- Anne Brown Discussion Groups Administrator Autodesk, Inc. Daniel Davison wrote: > (snip) > Is there an AutoDesk web site for bugs or is this it? (snip)
Message 8 of 9
Thanks "Anne Brown" wrote in message news:41929B70.E005A08E@autodesk.com... > > http://www.autodesk.com/submitbug > > This is your starting point for sending a message to Autodesk. > Use this form for general comments and questions, bug reports, > wish-list items, piracy reports, and so on > --- > Anne Brown > Discussion Groups Administrator > Autodesk, Inc. > > Daniel Davison wrote: >> > (snip) >> Is there an AutoDesk web site for bugs or is this it? > (snip)
Message 9 of 9
Hi Dan, I"m not entirely sure if this is an issue. For example, I tried the steps you suggested and created an iPart. In this, if you go between row 1 and 2 you can see that the extrusion2 (hole) size and the thread change accordingly. You need to make the hole diameter also as a key. Isn't it? Thanks. Shekar "Daniel Davison" wrote in message news:4192aee9$1_1@newsprd01... > Thanks > "Anne Brown" wrote in message > news:41929B70.E005A08E@autodesk.com... > > > > http://www.autodesk.com/submitbug > > > > This is your starting point for sending a message to Autodesk. > > Use this form for general comments and questions, bug reports, > > wish-list items, piracy reports, and so on > > --- > > Anne Brown > > Discussion Groups Administrator > > Autodesk, Inc. > > > > Daniel Davison wrote: > >> > > (snip) > >> Is there an AutoDesk web site for bugs or is this it? > > (snip) > >
