Inventor Forum
IV6 - INVENTOR.EXE WON'T REGISTER on my CPU!!!
17 REPLIES 17
Message 1 of 18
GLENNDOUT
625 Views, 17 Replies
Can anyone help ??
I cannot use Inventor Vr 6 on my Computer because the Software ( upon install or trying to run ) comes up with this message every time!
Autodesk Inventor (tm)
Inventor.exe is not currently registered and did not correctly re-register on start up. This is probably because you do not have enough access rights (e.g. you are a Restricted User). Ask an Administrator or Standard User to re-run the program for you.
This message keeps coming up on my system, even when I try to Install VoloView or Voloview express. They never register with my Computer either.
The funny thing is, I’m logged on as the Administrator! With no Passwords and having all permissions!
I have installed and uninstalled, then reinstalled and I still come up with the same problem! I have turned of any anti virus software before the install. Still come up with the same results ??
Here is my computers Stats.
Organization DESKTOP
Owner DESKTOP
ID 51873-OEM-0001472-06942
Computer Name DESKTOP
CPU GenuineIntel 1697 MHz Family:15 Model:0 Stepping:10 #of:1
OS Windows 2000(5.00) Build:2195 Service Pack 3
Memory Phys. 523740 KB __ Available : 315528 KB
Memory Page 1276736 KB __ Available : 1052180 KB
Memory Virt. 2097024 KB __ Available : 1921132 KB
IP Addr 127.000.000.001
Mouse Buttons 3 Wheel:1
Screen 1024 x 768
GraphicCard Mem. 64MB
Graphic ChipType GeForce2 Ultra
Graphic AdapterT... NVIDIA GeForce2 Ultra
Graphic AdapterStr. GeForce2 Ultra
I have searched my Registry file for anything that says AUTODESK and deleted it. Then I searched for VOLOVIEW and deleted this. I reinstalled INVENTOR 6 and I still come up with that Message.
And I get the Same Results with VoloView or VoloView Express!
It won’t register! And therefore I cannot get the software started.
Therefore, until someone can help me, I cannot Teach or Learn INVENTOR 6. I would really like to use the software.
If we can’t get the software to SELF-Register, Can you help me Manually Register the Software?
WORK PH# 757-858-8680 At work every day EST 8-6 pm
Glenn
17 REPLIES 17
Message 2 of 18
in reply to: GLENNDOUT
Can you try rebooting in Safe Mode and installing
Inventor 6 from there?
Can
anyone help ??
             Inventor.exe
for you.
This message keeps
the same results ??
Here is my
computers Stats.
 Owner DESKTOP
 ID
 CPU
 OS Windows
KB
 IP
 Screen 1024 x
768
 Graphic
Glenn
Message 3 of 18
GLENNDOUT
I'll give it a try!
thanks
Message 4 of 18
GLENNDOUT
Sorry, I tried to install or uninstall from safe mode and WIN2000 tells me that the installer services will not work in SAFE MODE!
Message 5 of 18
D'OH!
Sorry,
Message 6 of 18
As I replied in a thread named almost the same
thing as this one...I've had this problem. I was able to fix it by checking the
Task Manager. There was another instance of Inventor running in the background
somewhere. I stopped the task, then tried IV again. IT started right
up.
Can
anyone help ??
             Inventor.exe
for you.
This message keeps
the same results ??
Here is my
computers Stats.
 Owner DESKTOP
 ID
 CPU
 OS Windows
KB
 IP
 Screen 1024 x
768
 Graphic
Glenn
Message 7 of 18
Glenn,
This still sounds like a permissions issue, like
you do not have sufficient rights to teh registry to install the
software.
This is likely the case if this is a new computer
from a major OEM that has Windows XP Home or Pro on it.
Search for this document in the AutoDesk Knowledge
base, it talks about LT but will apply to Inventor.
Hope this helps,
Robert
Message 8 of 18
GLENNDOUT
DAVE,
Thank you very much, but I have already tried this. I still get the Same problem.
I think that AUTODESK is having a problem with some other software that is loaded on my cpu.
Suspects are
WIN FAX PRO or the OCR Software.
But I cant figure out why it is that only the AUTODESK software has a problem with my SYSTEM??? Any software Ive loaded for the past 2 yrs, NO PROBLEM. But Autodesk ??
Message 9 of 18
GLENNDOUT
Thanks Robert,
I went and printed and tried to do what the instruction told me to. Still I have the Same Problem.
Why is it that I have had no problems with any other software but when it comes to Autodesk products, Slam! My CPU doesnt want to do anything with it.
I have Solidworks, No Problem I have other CAD systems, NO PROBLEM, WHY AUTODESK????
Message 10 of 18
GLENNDOUT
Hello all,
I have created a new user and had that new user be part of the administrators group.
I logged on as this new user. I installed IV6, I still end up with the same Problem.
It thinks I dont have the proper permissions to register the INVENTOR.EXE file.
Signed, REALLY PO'ed
Message 11 of 18
Look like your pc's up to snuff, but don't have any idea what the problem
might be. With the holiday upon us, I would imagine an AutoDesk response
might me a little lacking, until maybe Friday. Seems like I remember a
similar (maybe the same) problem that was resolved recently. Search the
newsgroup using Google and see if you can find any hits. Good Luck.
"GLENNDOUT" wrote in message
news:f127e6b.8@WebX.maYIadrTaRb...
Hello all,
Problem.
file.
Message 12 of 18
pmmiles
I recently had an error while installing a video card driver, stating that I didn't have Administrator rights. The problem turned out to be that the network card had come unseated during shipping. Everything else installed fine, except the video driver. Perhaps the same idea? HTH
Message 13 of 18
GLENNDOUT
Thank you Mr. Phowells,
I to have on occassion had a loose card. However, Heres the thing I dont understand, Why would all of my other software be working on my CPU system and the AUTODESK Products won't?
What is it about the AutoDesk's Products and My PC?
I can't get Inventor, Voloview or Voloview Express to REGISTER when IM logged on as the ADMINISTRATOR?
Thanks Glenn
Message 14 of 18
Glenn,
Are you installing IV and running IV as the same
user?  If not, give that a try.
Hal
Message 15 of 18
GLENNDOUT
Please tell me what you mean? ---------------
If I logg on at the administrator, it doesn't work.
If I logg on as a user in the administrators Group, It doesnt work.---------------????
Message 16 of 18
GLENNDOUT
Heres More Information from my Computer Configuration.------------------------------------------------------------------
Autodesk Inventor 6--- Program: H:\Autodesk\Inventor 6\Bin\Inventor.exe
Last used: 11/25/2002
Frequency: occasionally (7)
Support information:
Publisher: Autodesk, Inc.
Version: 6.1.0000.10600
Standard information:
Uninstall: MsiExec.exe /I{76D6189D-0001-6000-0000-DFC2EE337EAC}
Modify: MsiExec.exe /I{76D6189D-0001-6000-0000-DFC2EE337EAC}--------------------------------------------
Est. Size: 598 MB
Display Icon: H:\Inventor 6\Bin\Inventor.exe,0
Install Date: 11/29/2002
Language: English (United States)
Source: G:\INVENT~1\Inventor\
by: Windows Installer
Key name: (HKLM) {76D6189D-0001-6000-0000-DFC2EE337EAC}------------------------------------------------------
Other information:
AuthorizedCDFPrefix= ''
Comments= ' '
Readme= ' '
Size= '
Version= '100728832 '
VersionMajor= '6'
VersionMinor= ''
Possible problems:
The program tracked in connection with this installation (H:\Autodesk\Inventor 6\Bin\Inventor.exe) does
not exist.-------------------UNDER THIS POSSIBLE PROBLEM REPORT, THIS IS NOT TRUE. THE INVENTOR.EXE FILE DOES EXIST UNDER THIS DIRECTORY!-------------THANKS GLENN
Message 17 of 18
Is IV on your local HD or on a server
drive?
Hal
Message 18 of 18
GLENNDOUT
YES, IV6 is installed on my Local Partitioned Hard Drive.
