Inventor Forum
IV2015: Publish Inventor FIle to DWF Error
3 REPLIES 3
blair
1027 Views, 3 Replies
I am getting the following error, never had this before with previous versions of Inventor: Failed to publish DWF file. Failed to publish model Failed to publish Design View "%1"
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
3 REPLIES 3
blair
in reply to: blair
Solved, bad drawing sheet.
Delta Tau Chi ΔΤΧ
in reply to: blair
Could I have a few more details about your solution? I'm also having this problem. Exporting drawings to dwf is fine but when I attempt to dwf the model it does not work. Message I receive is...
MattH_Work
Problem occurs for us with 2015 (RTM, RTM Update 1 & SP1 Update2) when creating DWF from a 3D Model with LOD's, or a drawing with views generated from LODS
If we produce the DWF from the drawing but only select sheets NOT 3D Models from the options everything works
LOD's are successful when DWFing from 2014
3D Assembly, Master LOD - SUCCESS
3D Assembly, Any LOD (with parts actually suppressed *) - FAIL
* I say this, as we can produce DWF's when using the 'All content Centre Suppressed' LOD if there is no CC in the Assembly, i.e., something has to be actually suppressed, as opposed to just selecting a LOD from the list
Regards
MattH
MattH
Product Design Collection 2025
Vault Pro 2025
