Solved by blair. Go to Solution.
Could I have a few more details about your solution? I'm also having this problem. Exporting drawings to dwf is fine but when I attempt to dwf the model it does not work. Message I receive is...
Problem occurs for us with 2015 (RTM, RTM Update 1 & SP1 Update2) when creating DWF from a 3D Model with LOD's, or a drawing with views generated from LODS
If we produce the DWF from the drawing but only select sheets NOT 3D Models from the options everything works
LOD's are successful when DWFing from 2014
3D Assembly, Master LOD - SUCCESS
3D Assembly, Any LOD (with parts actually suppressed *) - FAIL
* I say this, as we can produce DWF's when using the 'All content Centre Suppressed' LOD if there is no CC in the Assembly, i.e., something has to be actually suppressed, as opposed to just selecting a LOD from the list
Regards
MattH
