Inventor Forum
IV2012 Error Message
11 REPLIES 11
Message 1 of 12
BCrosby
551 Views, 11 Replies
One of our IV2012 stations is giving the operator a strange message. Any ideas? This comes up when he tries to get into application options.
Enter a number between 0.2 and 5.
Bruce M. Crosby
Broomfield
Engineering Department
GIGABYTE Z490 Vision D (Intel LGA1200/Z490/ATX/3xM.2/Dual Thunderbolt 3/SATA 6Gb/s/USB 3.2 Gen 2/Intel WiFi 6/Direct 12 Phase Digital Power/Intel 2.5G LAN/Motherboard)
Intel Core i7-10700K
Samsung (MZ-V7E1T0BW) 970 EVO SSD 1TB - M.2 NVMePNY Quadro P5000 VCQP5000-PB 16GB
Crucial Ballistix 3200 MHz DDR4 DRAM Desktop Gaming Memory Kit 128GB 32GBx4
Dell Ultrasharp U4919DW Curved 32:9 49” Display
Windows 10 Professional 64 Bit
CAT 7 Ethernet
HP Designjet T3500
3D Connexion SpaceMouse Enterprise
3D Connexion CadMouse
Autodesk Vault Basic 2020
Autodesk Inventor Professional 2020
Autodesk AutoCAD Mechanical 2020
11 REPLIES 11
Message 2 of 12
john.laidler
in reply to: BCrosby
Can you provide a screenshot of the error dialog?
John Laidler
AutoCAD, Inventor and Vault
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 3 of 12
BCrosby
in reply to: john.laidler
See Attachment
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
Message 4 of 12
KevinLi-Autodesk
i suppose there is some problems in your last operation before getting into application options, can you give more information here ? you can try to save your files then close & relaunch Inventor.
Kevin Li
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Message 5 of 12
RyanBotha
Looks like Win 98! Or 2000?
Message 6 of 12
BCrosby
in reply to: RyanBotha
Running Windows XP
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
Message 7 of 12
BCrosby
in reply to: KevinLi-Autodesk
We have already closed all files, rebooted, relaunched Inventor, still happens.
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
Message 8 of 12
Todzilla60
Did anyone figure out how to fix this? I am now getting the same error message... "Enter a number between 0.2 and 5." when i try to enter application options.... i am using Inventor 2012....
Message 9 of 12
Todzilla60
in reply to: Todzilla60
nevermind i figured it out....
Message 10 of 12
SBix26
For those who might stumble on this later, can you tell us what you figured out?
Message 11 of 12
jabman81
in reply to: SBix26
Hi, I know this is an older thread but I am having the same issue as the original poster.
I am using Inventor 2013 Design Suite Premium on a  Windows 7 64 bit professional O.S.
Inventor crashed on me and when I opened it up and went to change some dimensions on a sketch, the leader lines were there with no arrows and no dimension numbers. I was able to edit the dimension though. Figuring I might of changed the dimension style somehow I went to go into the Application options and got the same message as the OP.
Was there ever a solution to this problem?
Message 12 of 12
BLHDrafting
in reply to: jabman81
Only thing I can think of is doing a repair on the installation. Good luck.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
