Inventor General
Active Contributor
jabman81
Message 11 of 12 (105 Views)
Re: IV2012 Error Message
10-17-2012 12:31 PM in reply to: sbixler
Hi, I know this is an older thread but I am having the same issue as the original poster.
I am using Inventor 2013 Design Suite Premium on a  Windows 7 64 bit professional O.S.
Inventor crashed on me and when I opened it up and went to change some dimensions on a sketch, the leader lines were there with no arrows and no dimension numbers. I was able to edit the dimension though. Figuring I might of changed the dimension style somehow I went to go into the Application options and got the same message as the OP.
Was there ever a solution to this problem?
Valued Mentor
BLHDrafting
Message 12 of 12 (90 Views)
10-17-2012 05:45 PM in reply to: jabman81
Only thing I can think of is doing a repair on the installation. Good luck.
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
