Inventor Forum
IV2009 - Section view styles
6 REPLIES 6
Josh_Petitt
276 Views, 6 Replies
IV2009 Pro
Windows XP 64
I was happy to read about the new style control for section and balloon labels in the 2009 What's New. I've now installed and am experimenting.
We work with architects often that are used to seeing a view label and page number where the view is located with a asection view label. Also views are labeled with numbers not letters. Finally, they are very used to seeing a view "eyeball" (see attached pic) for showing where the viewpoint is on the base view.
Unfortunately, I was not able to figure out how to do any of these items with the new style formatting options.
As far as the eyeball, this might be hard to implement, but I was hoping that a custom symbol could be created that could be used as the section line label.
Also, it would be very nice to have the option of putting the page number where the view is located on the section line label. This helps the reader immensely.
Also, on a side rant, I see that the balloons and leaders have still not been "unified". There is still no balloon style that will give a horizontal break on the leader line. Instead the line runs straight into the balloon unless a horizontal section is explicitly created. Why is this? It is pretty obvious when you have a balloon and leader side by side on a drawing. It seems that Inventor could make this look the same thru the styles.
6 REPLIES 6
Josh_Petitt
in reply to: Josh_Petitt
here's the view eyeball, the view label is on top, the page where the view resides is on the bottom. The magenta arrow denotes the view direction on the base view.
We've seen that before, but supporting new or custom terminator shapes was
not part of this project. Essentially, the view annotation style was added
to make those annotation objects behave like others. With a few minor
exceptions, there's no new functionality there. It's really just a matter
of making it easier to make the kinds of changes you always could.
Andrew Faix
Product Designer
Autodesk Inventor
wrote in message news:5902859@discussion.autodesk.com...
IV2009 Pro
Windows XP 64
base view.
label.
immensely.
Josh_Petitt
Ok, thanks for the info Andrew. Guess I'll post a wishlist item and wait til next year. I still like the fact that there is a style for the labels now.
Me too. The eventual plan is to support sketch symbols as terminators, but
it's a long-lead project.
Andrew Faix
Product Designer
Autodesk Inventor
wrote in message news:5903393@discussion.autodesk.com...
now.
ivarr
Any chance that you are working on this Andrew Faix?
t_pcoll
in reply to: ivarr
Hi, support for referencing parent view's Sheet Name and/or Number from cut/section view label was added into Inventor 2015 version.
Please try "PARENT SHEET NAME" "PARENT SHEET INDEX" View Label Properties.
Ladislav
