The Shaft Generator portion of the Design Accelerator is intended to be used
during the design of your shaft. It is not set-up to analyze a part that you
have designed separately.
It should be easy enough for you to recreate your part within the Shaft
Generator and perform the analysis however you will "end up" with two parts.
HTH
- Gary
