Anyone having problems with Inventer 2014 when using a 3D mouse ?
I had multiple crashes when rotating with 3D mouse
If not, which 3D connexion drivers are you using ?
I would verify that your video card and driver are on the certified list. If needed install the certified driver. Then test to see if crashing is minimized. Next, If needed, uninstall the 3D Connexion driver and test Inventor. Then install latest 3D Connexion device driver. The certification link is below.
Verify Hardware certification
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Hopefully this helps.
Don
