Inventor General
Valued Contributor
Message 1 of 4 (178 Views)
Accepted Solution
IV 2013 Factory Design Suite- Appearance adjustment/change in Weldment
178 Views, 3 Replies
01-29-2013 06:37 PM
Hi
I was wondering if there is a way to change the appearance of a face in a weldment assembly environment. I have a weldment which in the machining process a part of weld bead as well as a portion of one of the componets is machined down (spot faced) and I need to change the apprearance of those face to polished, but it doesnt let me do that? is it me, or its not possible?
Warm Regards
*Expert Elite*
blair
Message 2 of 4 (169 Views)
Re: IV 2013 Factory Design Suite- Appearance adjustment/change in Weldment
01-29-2013 09:16 PM in reply to: 3DAli
Currently all the welds beads will change.  Select the weld bead (any weld bead) and then change the appearance from the Appearance drop-down menu and unfortunately all the weld beads in the assembly will change. Short of Photo-Shopping a picture I don't think it can be done
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Valued Contributor
Message 3 of 4 (154 Views)
01-30-2013 10:44 AM in reply to: blair
yeah, I thought so, cause I tried different ways and unfortunately I couldnt, if it was in a part environment, it was easy as you can change the appearance of any operation generated face through properties in the right click menu.
maybe a good one to add to wish list for future versions.
Thank you
Ali
Warm Regards
*Pro
sbixler
Message 4 of 4 (150 Views)
01-30-2013 10:50 AM in reply to: 3DAli
Inventor IdeaStation is the place to do that.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
