I can not find the toggle that sets the annotation to use the last used dim style. Help 🙂
Hi c.henry,
I'm not looking at 2012 right now, as I'm in the middle of something using an older version.
But it should be at:
Tools tab > Application Options > Drawing Tab
Set the Default Object Style drop down to Last Used.
I wasn't sure from your post if you'd looked there already or just couldn't recall where it was. Post back if you don't see it there.
I hope that helps.
Good luck with all of your Inventor pursuits,
Curtis
http://inventortrenches.blogspot.com/
Thats the first place I looked, was not there.
I went ahead and set up a new style with all the object defaults the way i want them. Probably should have done that years ago.
