Inventor Forum
ISO 606 Chains with support plate
3 REPLIES 3
MariaManuela
1309 Views, 3 Replies
Hi folk,
Its possible create through Design Accelerator ISO 606 Chains but with support plate like standard?
Please see the attached file.
Thanks in advance
(Inventor Pro 2014)
Asidek Consultant Specialist
www.asidek.es
Tags (1)
3 REPLIES 3
Paul-Mason
in reply to: MariaManuela
NO FILE ATTACHED
Looks like the Autodesk News Group System/Server is striping files off YET AGAIN when posting using IE10/11. At least thats the problem I've had for the past week or so.Smiley Frustrated
Best off using Google until they get off their hint ends and fix this latest Balls-upSmiley Mad
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
MariaManuela
in reply to: Paul-Mason
FILE HERE
Thanks for advice.
www.asidek.es
MariaManuela
Mail from Autodesk:
"Dear Manuela Pinho,
Thank you for choosing Autodesk Support.
This standard is not existing in Inventor currently. The ISO 606 basic chains are included in the Inventor library. Also, when you create a roller chain mechanism, you do not get the chain generated, but only a line representing the chain. This is done for performance reasons. If you want to create a full chain representation, you can use this utility: http://www.mechatronic.me/cad Roller chain Generator for Inventor
I hope this helps.
Best regards,
Daniela Koloszko Autodesk Support Team"
www.asidek.es
