Inventor General
*Wieczorek, Adam
Message 1 of 11 (291 Views)
IR6 - new SAT format, viewer needed
291 Views, 10 Replies
11-03-2002 11:32 PM
I'm using "ACIS 3D Open Viewer 6.0" for viewing SAT files exported from
Inventor.
All was fine until I6. My viewer sad "Bye!", sat format not supported, bad
luck :smileysad:
Does anybody know some nice, free SAT viewer ?
Aha, and it must be IE PlugIn, to work in HTML environment (that's a reason
why I do not want new version :smileyhappy:
Thx in advance ...
Adam
*Support\, Autodesk
Message 2 of 11 (291 Views)
Re: IR6 - new SAT format, viewer needed
11-03-2002 11:47 PM in reply to: *Wieczorek, Adam
Adam,
Just change the version of SAT file you are exporting by clicking the option
button.
Jason Ruge
Manufacturing Product Support
Autodesk, Inc.
"Adam Wieczorek" wrote in message
news:AD627A345629AA4338764CE20A61B228@in.WebX.maYIadrTaRb...
> Hi,
> Inventor.
> luck :smileysad:
reason
> Thx in advance ...
> Adam
*Keller, Kent
Message 3 of 11 (291 Views)
Re:
11-04-2002 12:29 AM in reply to: *Wieczorek, Adam
Hey neat... you learn something new every day
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Jason Ruge (Autodesk Support)" wrote in message
news:902559FE6D4E47411749A6953DAA31AE@in.WebX.maYIadrTaRb...
> Adam,
> button.
*darvinv
Message 4 of 11 (291 Views)
11-04-2002 04:55 AM in reply to: *Wieczorek, Adam
The new "700acishoopspartviewer" from spacial is a
real treat and works with IV6 acis files.
darvin
*Wieczorek, Adam
Message 5 of 11 (291 Views)
Re:
11-04-2002 03:42 PM in reply to: *Wieczorek, Adam
option
> button.
> Regards,
> Jason Ruge
SAT files are produced by kinda "robot" program which works via API. :smileysad:
Thx for trust in my brain :smileyhappy:
Adam
*Keller, Kent
Message 6 of 11 (291 Views)
Re:
11-05-2002 12:44 AM in reply to: *Wieczorek, Adam
Adam
The version to be saved is a registry setting that can be changed either manually or via
the API if needed. I am not sure but possibly ....does the setting stick after you do it
once in the file saveas dialog? If so then do a saveas once on a dummy part, setting the
version and then run your batch program.
Otherwise here is where the setting is stored.
All the normal Registry warnings......If you aren't familiar with the Registry don't mess
with it
Start the Registry Editor and locate the following key:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersionX.X\Translators\
SatTranslator
Create a new DWORD entry named SaveACISVersion and enter a value of 2, 3, 4,
5, 6 or 7. The value you enter represents the ACIS version used when you
export to the ACIS file format:
For example, if you enter a value of 5, an ACIS version 5 file is created
when you export to the ACIS file format.
Kent
news:BBDC62E4810530B9860397087504653F@in.WebX.maYIadrTaRb...
> option
> > button.
> > Regards,
> > Jason Ruge
> Adam
*darvinv
Message 7 of 11 (291 Views)
Re:
11-05-2002 01:03 AM in reply to: *Wieczorek, Adam
Kent,
    At least for now, at <
href="http://www.spatial.com">www.spatial.com
>, you can download
the hoops/acis viewer R7. Then do all your version changes there (let
inventor output at highest capability). It's free, it works well, it has
redlining, and you can back down to acis r1 if necessary. You can output an
assembly and throw out what you don't want in the viewer, rather than chase
down and output individual parts from IV.
darvin
ps. Wasn't I beating this drum about a year
ago?
*Keller, Kent
Message 8 of 11 (291 Views)
Re:
11-05-2002 01:14 AM in reply to: *Wieczorek, Adam
Darvin Sounds good, ... but that is another step. If they are using a program to batch
output Sat files I doubt they are going to want to open them all in another program and
manually manipulate them.
Kent
"darvinv" wrote in message
news:5E021D81E890FBFCFE8C40969FA8084F@in.WebX.maYIadrTaRb...
> Kent,
> At least for now, at , you can download the hoops/acis viewer R7.
Then do all your version changes there (let inventor output at highest capability). It's
free, it works well, it has redlining, and you can back down to acis r1 if necessary. You
can output an assembly and throw out what you don't want in the viewer, rather than chase
> darvin
> ps. Wasn't I beating this drum about a year ago?
*darvinv
Message 9 of 11 (291 Views)
Re:
11-05-2002 01:20 AM in reply to: *Wieczorek, Adam
I was thinking more in terms of whoever recieves
the files. That seems to be the short end!
darvin
*Wieczorek, Adam
Message 10 of 11 (291 Views)
Re:
11-05-2002 06:21 PM in reply to: *Wieczorek, Adam
Darvin,
Hoops viewer can't work like ActiveX placed on HTML page.
Ok, it can, but only for HSF files. Not for SAT format directly.
Old version (6) runs well.
I think so I will go with solution proposed by Kent.
Problem is so my ConvertingServer works for
Inventor/SolidEdge/SolidWorks/......
My final 3D format for view is SAT. All non-cad users need to view the
files.
Full layout is operated by PDM system which works in HTML/ASP environment.
Adam
Kent,
viewer R7. Then do all your version changes there (let inventor output at
highest capability). It's free, it works well, it has redlining, and you can
back down to acis r1 if necessary. You can output an assembly and throw out
what you don't want in the viewer, rather than chase down and output
darvin
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
