Scott,
I looked at the part and I am seeing a problem with hole1 not updating
correctly. This is weird.
Note: Why are the suppress/compute columns for Hole2,Mirror2, Mirror3, and
Hole3, all "0" and "1" instead of compute or suppress? Never seen it work
that way.
Here is what I am seeing:
1. Open the part and compute row "DIN Group 1 Heavy Weld Plate". Computes
fine. RMB Hole1 > Edit Feature and I note that the size is 10mm. Now
measure the diameter of hole1. It measures 8.5mm
2.Now compute "DIN Group 4 Heavy Weld Plate". Computes fine. RMB Hole1 >
Edit Feature and I note that the size is 12mm. Now measure the diameter of
hole1. It measures 8.5mm.
How can two different hole sizes measure the same??
Sorry, but I could not find what was wrong.
Kirk
"Scott Stubbington" wrote in message
news:B6806CFBCAFF9C2F80C79CB9D71D5AFE@in.WebX.maYIadrTaRb...
> Hello,
> I have posted the file to IvCf under the same heading, the threads in
Hole2
> are not working properly, the hole is not updating to the correct size,
just
> staying as is, however, if I edit the feature, all will be correct and as
I
> click the OK button, the holes and threads will update, can someone see if
> they get the same problem?
> Thanks
> Scott
