Inventor General
Active Member
anthonybu
Message 1 of 3 (398 Views)
INVENTOR PROFESIONAL 2013: FEA - Shock / Impact Load Analysis
398 Views, 2 Replies
01-08-2013 04:09 PM
Does the 2013 Inventor profesional embedded FEA have the capability of simulating shock loading?  eg: 25g for 12mili seconds.
*Expert Elite*
JDMather
Message 2 of 3 (372 Views)
Re: INVENTOR PROFESIONAL 2013: FEA - Shock / Impact Load Analysis
01-09-2013 04:19 AM in reply to: anthonybu
No.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
anthonybu
Message 3 of 3 (352 Views)
01-09-2013 01:02 PM in reply to: anthonybu
Ok thanks.
Now for the engineeirng question.  How can you use the frequency modal analysis in FEA, and the dynamic simulation to determine deflection and forces present for the acceleration over time, in order to get an equivalent static force to use in the stress analysis to determine peak stresses?  (obviously some manual calcs would be needed to do this)
If this is possible I would then think you could compare this stress with charpy impact material tests based on energy conservation to determine material failure?
Any help greatly appreciated.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
