*** INVENTOR FAQ: July 19, 2004 ***
### Table of Contents
1. Introduction and Rules & Regulations for the groups
2. List of all the Inventor Support Newsgroups (web & newsreader)
3. Frequently Asked Questions about R6/7/8
4. List of Inventor Websites and Resources
5. Bug Submission
6. Common Acronyms Used in the Newsgroups
PLEASE DO NOT CROSS POST TO MULTIPLE GROUPS. The exception to this rule is
information that applies to all releases (e.g. this FAQ, the Inventor World
Cup etc..) Post your question in the group to which version the question
pertains.
### 1.Introduction
Welcome Inventor users,
Below are a list of several resources to help with your use of Autodesk
Inventor. There is a lot of good information listed on these sites. Answers
to the more frequently asked questions can be found in these links.
If, after reviewing these sites, you still do not find the answer to your
questions please feel free to post in the newsgroup. There are a lot of
experienced users that will be more than happy to help you out if possible.
PLEASE DO A SEARCH OF THE GROUP FIRST(see below).
YOUR QUESTION HAS PROBABLY ALREADY BEEN ANSWERED.
Please familiarize yourself with the ground rules for these discussion
groups:
http://discussion.autodesk.com/ground.jspa
Please be descriptive in your topic subjects. Subjects like "Inventor
Problems" or "HELP!" do not lend much insight and are often skipped over. A
topic such as "How do I loft several non-parallel sketches" is much more
helpful.
As some newsreader programs cannot display HTML formatted messages
correctly, please be sure to post your messages in plain text format. Most
newsreaders have an option to format the messages in this manner.
If you are having display or crashing related issues please list your
machine's specs: Processor, RAM, Operating System, Video Card, IV release &
SP #. While it may not be due to these factors it helps to determine the
cause.
Do not post attachments larger than 1MB in this group. You may post larger
attachments in the CUSTOMER FILES newsgroup. Please move the end of part
marker to the top of the file and/or zip the files to save space.
ZIP ALL INVENTOR FILES!
You can find the customer files newsgroups here:
WEBBASED Inventor CF (Customer Files):
http://discussion.autodesk.com/forum.jspa?forumID=121
NTTP Inventor CF (Customer Files):
news://discussion.autodesk.com/autodesk.inventor.customer-files
### 2. List of the Inventor Newsgroups
As of July 6, 2003 Autodesk revamped their web based newsgroups. The URLs
to the groups changed.
Below is a listing of each of the Inventor related groups and links to both
the web based and newsreader versions of the groups:
Discussion Groups Main Menu
http://discussion.autodesk.com/index.jspa
Inventor Groups Main Menu
http://discussion.autodesk.com/index2.jspa?categoryID=21
Inventor 9
http://discussion.autodesk.com/forum.jspa?forumID=144
news://discussion.autodesk.com/autodesk.inventor.9
Inventor 8
http://discussion.autodesk.com/forum.jspa?forumID=75
news://discussion.autodesk.com/autodesk.inventor.8
Inventor Legacy (all content from Inventor 5.3, 6,and 7)
http://discussion.autodesk.com/forum.jspa?forumID=78
news://discussion.autodesk.com/autodesk.inventor.legacy
Inventor Customer Files
Autodesk Vault
http://discussion.autodesk.com/forum.jspa?forumID=101
news://discussion.autodesk.com/autodesk.vault
Inventor Customization (VBA and VB)
http://discussion.autodesk.com/forum.jspa?forumID=120
news://discussion.autodesk.com/autodesk.inventor.customization
Inventor Support (old group - now read only)
news://discussion.autodesk.com/autodesk.inventor.support
Old AutoCAD Customer Files Group (lots of old IV posts in here):
http://discussion.autodesk.com/forum.jspa?forumID=126
news://discussion.autodesk.com/autodesk.autocad.customer-files
Google search of the old (defunct) Inventor Support Newsgroup
http://groups.google.com/groups?hl=en&group=autodesk.inventor.support
### 3. Frequently Asked Questions about R6/7
Q) Where can I find SP1 & SP2 for R6?
A)
http://support.autodesk.com/getDoc.asp?id=DL403697 (R6SP1)
http://support.autodesk.com/getDoc.asp?id=DL403916 (R6SP2)
How about SP1 for R7?
http://tinyurl.com/eoah (R7SP1)
And SP1 for R8?
ftp://adeskftp.autodesk.com/prodsupp/downloads/Inventor8_ais_SP1.exe (AIS)
ftp://adeskftp.autodesk.com/prodsupp/downloads/Inventor8_aip_SP1.exe (AIP)
Q) Where did my print icon go in R6/R7/R8 ?
A)You can access printing commands via File>Plot. To add the icon to your
toolbar go to Tools>Customize and click on the last tab. Highlight
Management in the left hand pane and then drag the print icon onto the
standard toolbar in Inventor. You must do this for each file type. e.g.
start a new part file and do this, then close and repeat with assembly,
presentation and detail drawing file types.
Q) Why do my decals appear as icons?
A) You likely have .bmp file types associated with a viewer other than MS
Paint. To fix this see http://www.sdotson.com/freetut/Tips%20&%20Tricks.pdf
page 8 item # 18 or download iTweak at www.sdotson.com/vba.asp
Q) Why do some of my project paths appear in red?
A) There are nested paths. For example if you have a workspace defined as
C:\project and a path defined as c:\project\parts the latter path will
appear in red. See the Autodesk Inventor File Management Document.doc on
the 1st AIS CD for
more info about projects and how they work.
Q) Why do I get an error about not being able to edit a file?
A) Staring in R6 any file referred to in a library path cannot be edited. To
edit
these files you either need to move the library file out of the library
path, edit it and then return it to the library or create a new project file
that refers
to this file as a local or workgroup (non-library) path.
Q) Where is the content library in R6/R7/R8?
A) While in an assembly, left click on the word "Model" at the top of your
browser. This will activate a pulldown. Select Library from the pulldown.
From here you can select your content and drag and drop it into the
assembly.
Q) Why can't I rearrange parts in the assembly browser in R6/R7?
A) The ability to do this in R6 was removed due to the addition of assembly
features. The feature returned in R8.
Q) What is the reflection I see in some parts? It looks like a car..
A) It's a black Mazda Miata in the parking lot of Autodesk in Tualatin,
Oregon.
The owner is George Hudetz, a member of the Inventor Team.
file located in the Inventor install directory. A spherical fishbowl image
looks the best.
### 4. Inventor Related Websites and Resources
Drew Fulford's Inventor FAQ (Over 400 Inventor frequently asked questions)
http://www.mymcad.com
Sean Dotson's Inventor Tutorials & More
Sean Dotson's MCAD Discussion Forums
http://www.sdotson.com/forums/
Charles Bliss' iParts and iCode Repository
http://www.cbliss.com/inventor
Kent Keller's iParts and Code Site
http://www.kwikmcad.com/
Charles Bliss' Inventor Parts.com
http://www.inventorparts.com
Patrick de Stobbeleir's Inventor Tool Site
http://hjem.get2net.dk/opad/
Neil Munro's How-To Articles and Tips
http://tinyurl.com/dhki
Ole Germer's Site (Timken bearings, Involute Gears, Roller Chains etc.)
http://www.geocities.com/olegermer/index.html
CAD Studio (Czech based but in English)
http://www.cadforum.cz/cadforum_en/default.asp?tab=2&CAD=Inventor
Jorgen Bjornes' Scanadivan Inventor Site
http://www.inventorforum.net/
Elise Moss' Tips and Tutorials
http://www.mossdesigns.com/
The Netherlands Inventor Forum (mainly in Dutch)
http://www.inventorusers.nl/index.php
MCAD Brazil - Brazillian Inventor Site
www.mcadbrasil.net
Lars Jensen's Inventor Site (Danish and English)
http://www.inventordk.dk/
German Inventor FAQ
http://www.kacaju.de/
LeaCar LLC (Inventor Tools & Tutorials)
http://www.leacar.com/default.shtml
Autodesk's Inventor Users Site (iDrop Parts, Articles & Tutorials)
http://tinyurl.com/7mgm
Autodesk Inventor Graphic Card & Driver Info
http://www.autodesk.com/us/inventor/graphic_cards/
Autodesk's Knowledge Base
http://support.autodesk.com/enu/Homepage.asp
Autodesk Skill Builders Tutorials
http://tinyurl.com/2s99w
AUGI (autodesk Users Group International) Guilds
email lists for Inventor (and other product) support
http://www.augi.com/
Official Autodesk Inventor Feature Wishlist Submission Link
http://usa.autodesk.com/adsk/item/0,,1073397-123112,00.html
Official Autodesk Inventor Product Information Page (likes to other pages)
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2280662
Autodesk University 2003 Class Handouts
www.autodeskevents.com/au2003/session_handouts.cfm
Various Yahoo Inventor Groups
http://groups.yahoo.com/group/Inventor_Parts
http://groups.yahoo.com/group/inventorapi
http://groups.yahoo.com/group/InventorJobsCanada
http://groups.yahoo.com/group/InventorJobsUSA
http://groups.yahoo.com/group/woodinventor
http://groups.yahoo.com/group/InventorJobsOntarioCanada
http://groups.yahoo.com/group/autodeskinventors
http://groups.yahoo.com/group/inventorusers
### 5. Bug Submission Procedure
###Bug Submission
If you think you may have found a new bug:
1. Go to the Autodesk website: http://www.autodesk.com
2. Click on "Contact Us".
3. Click on "Feedback" in the left hand menu.
4. Click on "Products" in the left hand menu.
5. Click on Submit a bug report
5. Now you show see the "Bug Report Submission" web page.
6. Read the instructions, fill out the form, and press the "Submit Bug
Report" button
Or directly go to the Bug Report Submission" web page:
http://usa.autodesk.com/adsk/item/0,,1073063-123112,00.html
More bug report info from Autodesk:
"You can also either report it through your reseller or call Autodesk's
Safety Net support number at 800-225-6531. If it is determined that what you
are calling about is a defect you will not be charged for the Safety Net
call."
### 6. Common Acronyms Used in the Groups
NG = newsgroup
CF = customer files (see above for links)
iCF = Inventor customer files (se above for links)
IV = Inventor
R5SP2 = Inventor Release 5 Service Pack 2 (or any other combo of numbers)
W2K=Windows 2000
RMB = right mouse button
DA = Design Assistant
DM = Drawing Manager (a.k.a. the IDW environment)
=grin = very big grin (etc..)
for more go to http://www.gaarde.org/acronyms/
###PLEASE DO NOT RESPOND TO THIS POST.
Kent Keller
PS: If you have other sites that you think are useful or general comments,
reply to me by email
