Inventor Forum
INV 6 SP1 .IDW Red boxes on views
2 REPLIES 2
135 Views, 2 Replies
The red boxes on the views are not updating. Anyway to speed this up? Or is
it even worth worring about?
Fred
2 REPLIES 2
If they are shaded view they will not update.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
"Fred Sands" wrote in message
news:AD5A50800C717C715919C064988F98B2@in.WebX.maYIadrTaRb...
is
> Thanks,
> Fred
you could also check the IV6 newsgroup at autodesk.inventor.6
A couple of things to mention:
- Shaded views will never go precise (change from red to black.)
- make sure that you have "make views precise" checked for automatic view
regeneration if you don't you can RMB each view select "make view precise"
- sometimes it does take a long time, make sure that you aren't bogging down
your computing power with many other processes at the same time.
K
is
> Thanks,
> Fred
