Hi everyone,
I have the following problem, after the inventor start I chose create a parte, assembly, drawing or anything, the programm crashes. It does not matter if I select New from the welcome windows or close the welcome windows, then File>New. Always crashes.
I have repair the installation and nothing. Also I did a Reinstall and nothing.
The last thing I did was to create a new Windows user and the Inventor works just fine.
Any help anyone?
Is there a way I could "clean" my windows user of Autodesk configuration? or something like that?
Thank you,
Luis
Luis José Andueza Castro
Ing. Mecánico - Consultor CAD/CAM/CAE/Data Management
www.dimcad3d.com | LinkedIn |
¿Te resultó útil esta publicación? No dudes en darle Me gusta a esta publicación.
¿Tu pregunta fue respondida exitosamente? Entonces haz clic en el botón ACEPTAR SOLUCIÓN.
Hi John,
I tried a serach but nothing.
The other thing I did was delete the file inside the directory:
C:\Users\Username\AppData\Local\Autodesk\AdLM
And now Inventor 2013 is working.
If something change or stop working I will inform you.
Bye
