For 3 days going thru utube, help files, forums etc. I've been trying to get AutoCad borders to paste, insert, save into, block, dwg, dxf, dwt, ect, and anythign else I can find to get it to possibly go into Inventor. I mean really? it's that impossible to have two Autodesk products and they wont communicate some files? I could understand if this is the first year of Inventor, but by now it seems they would have run accross this a few hundred times.
So, PLEASE, someone please help with some working advise on how to make this happen. I've tried everything, and getting very frustrated.
Solved by nicolas.leclercMPQMB. Go to Solution.
Solved by Cadmanto. Go to Solution.
Go to open, select your file, select the options button at the bottom and select import. Follow the steps and select the layer your title block is on.
HI mbs100k,
I understand that you're frustrated, but you didn't give us much to go on, as far as helping you with your goal. You mention you tried several things but nothing worked.
Can you provide some example files so that we can look at the file inputs? Or maybe some screen shots, or at the very least a bit more detail on how it's not working?
If you can not provide details such as this, can you confirm that you've tried just copying and pasting from AutoCAD into Inventor?
Also, what version of Inventor are you using?
I hope this helps.
Curtis
Not sure if this will help you, but one thing you could do is call up your Autocad .dwg file into a session of Inventor, then do a file>save as copy amd change the file type to .idw
Then tweak it from there.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
You can do this
Go in autocad, copy you block. Right click copy or ctrl C
Go in inventor, in your .idw, start a sketch, nowehere important
Paste, with right click or with ctrl V
Close sketch and now your sketch is your autocad block.
Do you realize that this is a 6-1/2 year old thread you are responding to? The OP probably is waaaay beyond this by now!!! 😄
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Yes i know it's a 6 years old thread but it's in the firsts thread supplyed by google for my interrogation. And the solution i wrote worked for me, so I thoutght why not write it down so it could help someone helse having the same trouble.
