Inventor General
New Member
Message 1 of 3 (150 Views)
Accepted Solution
IMPORTED PART, EDITING ISSUE - PLEASE HELP
150 Views, 2 Replies
12-03-2012 06:40 AM
Good morning,
I recently downloaded a .SAT part from 3dcontentcentral.com and i would like to use it in an assembly i am creating.  Problem is, once i pulled it into Inventor, I am unable to edit the part to match the dimensions necessary for my assembly.  How do i go about editing this part? Is there a way that i can copy the components of the part and paste into a new drawing, save as a normal part, then edit?  I have attached a screenshop of the part so you can see the Model tree.  Any help would be greatly appreciated!
p.s. I would simply redraw the part, however i am having a lot of difficulty getting it to look as i want it to.
Michelle
*Expert Elite*
MariaManuela
Message 2 of 3 (136 Views)
Re: IMPORTED PART, EDITING ISSUE - PLEASE HELP
12-03-2012 07:02 AM in reply to: 0964080
Hi Michelle,
Sorry but SAT files are models with no history, called dead bodies.
Is better redraw if you need change the dimensions.
Maria Manuela Pinho
Application Specialist
Cadtech - Asidek | Autodesk Gold Partner
https://www.facebook.com/cadtech.asidek
www.cadtech.pt | www.cadtech.es | www.asidek.es
Autodesk Inventor Professional 2014 (Product Design Suite - Ultimate)
Lenovo W520
*Expert Elite*
Message 3 of 3 (129 Views)
12-03-2012 07:05 AM in reply to: 0964080
What do you need to change on the original part?
You can Delete Face with Heal option to remove the holes.
There are other ways to edit base solids, but more information is needed on the design intent.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
