Inventor General
Member
shaiadle
Message 1 of 6 (873 Views)
ILogic rule for modeling/sheet metal state
873 Views, 5 Replies
10-06-2011 12:41 AM
Hellow,
Deos anyone know how what is the iLogic rule for identifying if a part is in a "modeling" state or "sheet metal" state?
Shai
Curtis_Waguespack
Message 2 of 6 (855 Views)
Re: ILogic rule for modeling/sheet metal state
10-06-2011 09:42 AM in reply to: shaiadle
Hi shaiadle,
You can use a conditional such as this to check for the existence of a flat pattern:
If oSMDef.FlatPattern Is Nothing Then
Here's a quick example:
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
'ensure this part has a flat pattern
Dim oSMDef As SheetMetalComponentDefinition
oSMDef = oDoc.ComponentDefinition
'tell the user there is no flat pattern
MessageBox.Show("This file has no flat pattern", "iLogic")
Else
'tell the user there is a flat pattern
MessageBox.Show("This file does have a flat pattern", "iLogic")
end if
but to answer your question more directly, you can use the FlatPattern.ExitEdit method to return to the folded model, if the model is in the Flat Pattern environment:
oSMDef.FlatPattern.ExitEdit
and conversly you can use the FlatPattern.Edit method to return to the flat pattern, if the model is in the folded environment:
oSMDef.FlatPattern.Edit
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Mentor
rjay75
Message 3 of 6 (843 Views)
10-06-2011 10:45 AM in reply to: shaiadle
If you're just trying to determine if the active document is a sheet metal part versus standard part this code may help.
Dim curDoc = ThisApplication.ActiveDocument
If curDoc.DocumentType = kPartDocumentObject Then
	'This is a Part Drawing
	If curDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		'This is a SheetMetal Part
		MessageBox.Show("This is a sheet metal part.", "SMCheck")
	Else
		MessageBox.Show("This is a standard part.", "SMCheck")
	End If
End If
Active Contributor
WHassan
Message 4 of 6 (505 Views)
09-10-2012 02:24 PM in reply to: rjay75
Thanks Rodney,
Is there a help resource where I can find the "text" for all the Sub-Types of files.
I am trying to output them on the immediate window, but it seems to give me a troubles (or maybe I dont know how to get imformation on the Immediate window yet)
Wajih
Valued Mentor
niksasa
Message 5 of 6 (239 Views)
10-08-2013 11:33 AM in reply to: Curtis_Waguespack
Curtis_Waguespack написано:
Hi shaiadle,
Else
end if
 I have this code does not work in ilogic
САПР - это инструмент, но только при условии грамотного подхода.
Curtis_Waguespack
Message 6 of 6 (235 Views)
10-08-2013 11:35 AM in reply to: niksasa
Hi niksasa,
If you are using Inventor 2014, then this might be related to this problem:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Subtype-Sheet-Metal-file-changed-in-In...
I hope this helps.
Curtis
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
