Inventor Forum
ILogic rule for ipt browser node renaming?
2 REPLIES 2
1876 Views, 2 Replies
Hi all,
is it possible to rename the browser node on part level with an iLogic rule? I know that in the assembly environment is an Inventor OOTB functionality to rename the nodes to the filename, Part number or the default value.
Any help would be appreciated.
Raphael
2 REPLIES 2
Jon.Dean
Take a look at the following website, I think it will answer your question:
http://ellipsis-autodesk.typepad.com/blog/2010/06/new-ilogic-web-series.html
If you need more help then let me know.
Jon
Jon Dean
in reply to: Jon.Dean
Hi Jon,
thanks for your help. I found the soulution here:
http://forums.autodesk.com/t5/Autodesk-Inventor/Inv-2011-How-do-I-set-quot-Part-Number-quot-as-the-d...
This is exactly what I was looking for.
I am now using an iLogic rule to compose the part number in the ipt file (it is a comination of a special item name and various part dimensions, and then the "UpdateAssyBrowser" rule is updating the browser names in assembly environment. Works great.
Bye
Raphael
