Inventor General
Distinguished Contributor
Message 1 of 2 (126 Views)
ILOGIC edit part parameter
126 Views, 1 Replies
06-25-2013 02:22 PM
Is it possible with iLogic code to set a parameter in a bunch of parts equal to another paramter?
I want some iLogic code that will go into my pipe parts and make the PL param = D2.
Doable?
Employee
Message 2 of 2 (106 Views)
Re: ILOGIC edit part parameter
06-26-2013 12:20 AM in reply to: cstringer80
Hi
You can try below code to your assembly file, it will check occurrences in your assembly and modify the value of PL and make it equal to D2.
I saw your previous post on Pipe Length, please notice some type of Pipe, like thread pipe, its default length parameter refer to D3 other than D2.
' Set a reference To the Assembly Component definintion.
' This assumes an assembly document is open.Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrencesDim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
'check for and skip virtual components
'(in case a virtual component trips things up)If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
Parameter.Quiet = True
Parameter(oOccurrence.Name, "PL") = Parameter(oOccurrence.Name, "d2")
InventorVb.DocumentUpdate()
Else
End If
Next
Inventor Professional 2014
Jingyi Liu
Quality Assurance Team
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
