Inventor General
Active Contributor
Message 1 of 4 (107 Views)
IDW View Partial Update
107 Views, 3 Replies
11-01-2002 08:04 AM
After updating a part, I noticed that one of the drawing views didn't update fully. The dimensions "think" that the
view was updated, since the hole center marks and dimension leaders are all positioned where the geometry
SHOULD be. But the actual geometry didn't update. This only occurred in the base view - all of the projected
views updated properly. I've tried forcing an update by checking and unchecking the defer updates option, but
no luck. If I create a new base view (of the same view), the geometry is properly updated. Any ideas? I would
ordinarily just say a few choice words, delete the view, and "simply" create a new one; but this is the base view
(of course), and my whole sheet is based on it...
V/R - Nate Alday (IV 6, Dual Xeon 2.2, 2 Gb RAM, Quadro 750XGL, XP Pro)
*Caldwell, Larry
Message 2 of 4 (107 Views)
Re: IDW View Partial Update
11-01-2002 08:15 AM in reply to: nathan.alday
Think you can Edit View and un-tick the base view
reference to make the views independent.
~Larry
After
SHOULD
no luck.
(of
Pro)
*Carr, Jimmy
Message 3 of 4 (107 Views)
11-01-2002 10:16 AM in reply to: nathan.alday
Nate.  Have you selected the view and hit the
local update icon (lightning bolt)?  Might work.
After
SHOULD
no luck.
(of
Pro)
Active Contributor
Message 4 of 4 (107 Views)
Re:
11-04-2002 12:03 AM in reply to: nathan.alday
Ahhhh, so you have to select the VIEW to get the
lightening bolt! I learn something new every day.
Thanks!
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
