Inventor Forum
ICopy: "This ICopy-Element can't be edited..."
3 REPLIES 3
dominik.gleinser
492 Views, 3 Replies
Hallo,
I have following problem with ICopy:
Edit with ICopy:
When I'm doing this, I get following error message: "Dieses ICopy-Element kann nicht bearbeitet werden, da die Struktur der Vorlagenbaugruppe verändert wurden"
In English: "This ICopy-Element can't be edited, because the structure of the original assembly has been changed"
3 REPLIES 3
The exact message in english is :
Cannot edit this iCopy feature because the structure of the template assembly is changed
You probably did a change in the Icopied Assembly. I think the best way is to delete this Icopy and reinsert it.
Pierre Masson Product Support Specialist PS MFG EMEA Autodesk, Inc.
Thank you for your answer,
but I have already tried to reinsert the assembly....the same problem again!
Do you have other solutions?
Perform a complete rebuild all of the assembly (vi Task scheduler), and reauthor it with Icopy.
Then try to reinsert. If this does not work, please send it to me.
