Inventor General
dominik.gleinser
Message 1 of 4 (189 Views)
ICopy: "This ICopy-Element can't be edited..."
189 Views, 3 Replies
04-20-2012 12:05 AM
Hallo,
I have following problem with ICopy:
Edit with ICopy:
When I'm doing this, I get following error message: "Dieses ICopy-Element kann nicht bearbeitet werden, da die Struktur der Vorlagenbaugruppe verändert wurden"
In English: "This ICopy-Element can't be edited, because the structure of the original assembly has been changed"
Product Support
pierre.masson
Message 2 of 4 (158 Views)
Re: ICopy: "This ICopy-Element can't be edited..."
04-24-2012 02:39 AM in reply to: dominik.gleinser
The exact message in english is :
Cannot edit this iCopy feature because the structure of the template assembly is changed
You probably did a change in the Icopied Assembly. I think the best way is to delete this Icopy and reinsert it.
Pierre Masson Product Support Specialist PS MFG EMEA Autodesk, Inc.
dominik.gleinser
Message 3 of 4 (155 Views)
04-24-2012 03:30 AM in reply to: pierre.masson
Thank you for your answer,
but I have already tried to reinsert the assembly....the same problem again!
Do you have other solutions?
Product Support
pierre.masson
Message 4 of 4 (138 Views)
04-25-2012 03:22 AM in reply to: dominik.gleinser
Perform a complete rebuild all of the assembly (vi Task scheduler), and reauthor it with Icopy.
Then try to reinsert. If this does not work, please send it to me.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
