Inventor General
Distinguished Contributor
tdrawdy
Message 1 of 10 (103 Views)
I should probably know this, but....
103 Views, 9 Replies
12-12-2002 03:49 AM
I got this message on a new part that I was designing. I have not had this error pop-up before on the 100 or so parts or assemblies that I have produced in the past. The project does not have any broken links (that would highlighted in red). I have also noticed that everything in that directory now has the same error when trying pick a plain to sketch on. This is probably operator error, but I am at a loss.
Cannot modify the library file H:\ENGINEER\BLOCKS\3-D\gfi outlet.ipt
*KJohnson
Message 2 of 10 (103 Views)
Re: I should probably know this, but....
12-12-2002 03:57 AM in reply to: tdrawdy
Libraries are now read only.  You need to make
another project without libraries if you want to edit a library
part.
Kathy Johnson
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
but I am at a loss.
outlet.ipt
*Chartrand, Pat
Message 3 of 10 (103 Views)
Project files have changed in R6
For one thing, if a path is showing in red in the
project dialog box it means that it is somewhat redondant and that you do not
need it any more. If you are to leave it there, you ar eslowing down the opening
process.
Second thing, to answer the question, the file you
are trying to modify is residing in a folder that is marked has a library in
your project dialog box.
Now either you decide that this is not a library
part and you move it in sub folder of your workgroup path...OR you create
yourself a 'library editing project file' that will point to your library folder
on your system as  workgroup path....
I know this can get confusing, but this new way
provides for faster assembly file resolution.
Good day
Patrik Chartrand
I
but I am at a loss.
outlet.ipt
*Bartels, Joe
Message 4 of 10 (103 Views)
12-12-2002 03:58 AM in reply to: tdrawdy
Is the directory that your files are located in
have an entry in the Library Search Paths in your project file.  Any files
that are in these locations are considered read-only.
Joe Bartels
I
but I am at a loss.
outlet.ipt
*Dotson, Sean
Message 5 of 10 (103 Views)
Re:
12-12-2002 04:12 AM in reply to: tdrawdy
"For one thing, if a path
is showing in red in the project dialog box it means that it is somewhat
redondant and that you do not need it any more. If you are to leave it there,
you ar eslowing down the opening process."
However for small projects the advantages of having
links the left hand pane can outweigh the relative small slowdown of the
resolving of files.  (I'm not gonna let this one die
<g>)
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
opening process.
you are trying to modify is residing in a folder that is marked has a library
in your project dialog box.
folder on your system as  workgroup path....
Good day
Patrik Chartrand
I
outlet.ipt
*Pawelski, Andrew
Message 6 of 10 (103 Views)
Re:
12-12-2002 04:14 AM in reply to: tdrawdy
Small projects maybe... but be careful, we were
having all sorts of problems with the Multi-User Semi-Isolated mode while having
these redundant or red paths. Once we eliminated them, we eliminated the
problems.
Andrew
having links the left hand pane can outweigh the relative small slowdown of
the resolving of files.  (I'm not gonna let this one die
<g>)
tdrawdy
Message 7 of 10 (103 Views)
Re:
12-12-2002 04:33 AM in reply to: tdrawdy
This was the problem. I was referencing the working directory in the library search path. I think that I may have done this in the past also. Thank you and everyone who put me back on the right track.
Tom Drawdy
*Yeandle, Laurence
Message 8 of 10 (103 Views)
Re:
12-12-2002 06:21 PM in reply to: tdrawdy
Why does IV 6.0 "samples" project have a ton of red
paths?
Laurence,
Power is nothing without
Control
<g>)
Sean Dotson, PE
Check the Inventor
the project dialog box it means that it is somewhat redondant and that you
do not need it any more. If you are to leave it there, you ar eslowing down
library in your project dialog box.
library part and you move it in sub folder of your workgroup path...OR you
create yourself a 'library editing project file' that will point to your
library folder on your system as  workgroup path....
Good day
Patrik Chartrand
I
outlet.ipt
*Caldwell, Larry
Message 9 of 10 (103 Views)
Re:
12-13-2002 07:57 AM in reply to: tdrawdy
Gust a guess, but if they weren't native R6 to
start with, they probably never changed the nested paths.
~Larry
red paths?
Laurence,
Control
path is showing in red in the project dialog box it means that it is
somewhat redondant and that you do not need it any more. If you are to leave
it there, you ar eslowing down the opening process."
<g>)
Sean Dotson, PE
Check the
Inventor FAQ for most common questions
file you are trying to modify is residing in a folder that is marked has a
way provides for faster assembly file resolution.
Good day
Patrik Chartrand
I
outlet.ipt
*Howard, Jeff
Message 10 of 10 (103 Views)
Re:
12-13-2002 08:40 AM in reply to: tdrawdy
For the same reasons the results of Pack and Go have tons of red paths?
8~)
"Laurence Yeandle" wrote in message
news:CFB1534F8552837DC1B020FBAF947675@in.WebX.maYIadrTaRb...
Why does IV 6.0 "samples" project have a ton of red paths?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
